RV.Net Open Roads Forum: Class A Motorhomes: water dripping off ac
 > water dripping off ac
straycat59
Virginia
Posted: 04/01/12 08:11am Link  |  Print  |  Notify Moderator
Hi':-)
Problem child again. Can someone tell me why my AC drips water and comes down the side of my RV. Is it because I'm not level. THANK YOU
harold1946
Surprise Arizona
Posted: 04/01/12 08:17am Link  |  Print  |  Notify Moderator
Perfectly normal. Its just the condensation draining off from the ac.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
Chinook
Missouri
Posted: 04/01/12 08:55am Link  |  Print  |  Notify Moderator
Air conditioners will dehumidify the air.
Condensation is natural if your air conditioner is functioning properly in a humid climate.
There is a drain in the pan that is under the inside coil (the cool one) that should drain this condensation so that it doesn’t enter the RV. Some units simply dump the water onto the roof and others transfer the water to a location where the outside fan flings the water on to the outside coil (the hot one) to evaporate the water and increase the efficiency of the unit.
TN Tarheel
East TN
Posted: 04/01/12 08:57am Link  |  Print  |  Notify Moderator
Real problem would be if it didn't run off.
pianotuna
Regina, SK, Canada
Posted: 04/01/12 09:07am Link  |  Print  |  Notify Moderator
Hi,
It is normal.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
rr2254545
Minnesota/New Mexico
Posted: 04/01/12 08:58am Link  |  Print  |  Notify Moderator
Remember this is April fools day - this might not be a real question
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
J&R
jefferson,ga
Posted: 04/01/12 09:24am Link  |  Print  |  Notify Moderator
Had to put gutter extensions on both front sides of ours. Water was wearing into finish on side.
Ron & Joanne 06 Revolution LE 40E
pbitschura
SE MN
Posted: 04/01/12 09:48am Link  |  Print  |  Notify Moderator
Remember, this is April Fools Day. This might not be a real response.
1988 Mallard class c 24' Chevy chassis 350 cu gas.
straycat59
Virginia
NO IT'S NOT APRIL FOOLS! It's a real question. I'm solo and still new be and appreciate all advice. It's an older RV 1989. But I probably need to have it serviced yearly I assume. Thanks for not laughing outloud
pbitschura
SE MN
Posted: 04/01/12 09:49am Link  |  Print  |  Notify Moderator
It will run off somewhere. Our runs out of the gutter near the front door.
