RV.Net Open Roads Forum: Class A Motorhomes: water dripping off ac
 > water dripping off ac
rr2254545
Minnesota
Posted: 04/01/12 10:28am Link  |  Print  |  Notify Moderator
pbitschura wrote:
straycat59 wrote:
NO IT'S NOT APRIL FOOLS! It's a real question. I'm solo and still new be and appreciate all advice. It's an older RV 1989. But I probably need to have it serviced yearly I assume. Thanks for not laughing outloud
It will run off somewhere. Our runs out of the gutter near the front door.
Mine runs down the rear near the ladder.
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
wny_pat
Western NYS
Posted: 04/01/12 11:38am Link  |  Print  |  Notify Moderator
You live in Georgia and you didn't know that Air Conditioners drip condensation? Gotta be a April fools day thing!
dougrainer
Carrolton, Texas
Posted: 04/01/12 12:34pm Link  |  Print  |  Notify Moderator
This is a common complaint from RV novices. They think something must be wrong because the water comes off the roof. Doug
rvrepairnut
bc
Posted: 04/01/12 01:09pm Link  |  Print  |  Notify Moderator
dont matter where u live they all drip condensation same as your truck or car does
Old-Biscuit
Across the USA
Posted: 04/01/12 03:53pm Link  |  Print  |  Notify Moderator
Just be thankful it's running off the roof and down the OUTSIDE of rig and not the INSIDE of rig.
OUTSIDE>>>>>>>>Good
INSIDE>>>>>>>>>Not so good. (Inside means drain pan/drain holes plugged up and requires a trip up on roof, shroud removal, evap cooler cover removal, cleaning pan/drain holes, putting evap cooler cover back on----sealing it, shroud back on and then climbing down off roof)
Klueck
Posted: 04/02/12 08:10am Link  |  Print  |  Notify Moderator
Some rv's have drains where the ac condensation runs. If you don't, it will run right off the roof and to the lowest point. Every time you park it may run off at a different spot, depending on how level you are.
Not a dumb question and don't feel bad for asking it.
joraz
Tucson
Posted: 04/02/12 08:46am Link  |  Print  |  Notify Moderator
I sure don't think it's a dumb question. I marvel at the fact that many rigs sell for hundreds of thousands and don't divert the water in a more elegant fashion. When we first started RVing, I had the same question. Good luck on your travels.
jor
95 Foretravel
Cummins M11 400
Allison 4060
