RV.Net Open Roads Forum: 30 amp circuit in garage for RV - does it require a GFI?
 > 30 amp circuit in garage for RV - does it require a GFI?
wolfe10
Posted: 04/01/12 08:49pm Link  |  Print  |  Notify Moderator
ktmrfs wrote:
just out of curiosity, has anyone even seen anyone who sells a 30A 120V GFI breaker ?? All I've ever seen are 15A and 20A 120V GFI breakers.
Sure, for hot tubs, etc. Lowes, etc has them.
http://www.lowes.com/pd_109124-1318-QF23........3FNtt%3Dsiemens&facetInfo=$50%20-%20$100
* This post was edited 04/01/12 08:57pm by wolfe10 *
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
travisc
Pacific NW
Posted: 04/01/12 08:50pm Link  |  Print  |  Notify Moderator
I purchased ours at our local hardware store-
Winnebago Access 24V
CA Traveler
The Western States
Posted: 04/02/12 08:37am Link  |  Print  |  Notify Moderator
As stated you don't need a 30A GFCI. However, it's a very good idea to periodically plug into a 20A GFCI, turn on devices one at a time and make sure the rig hasn't developed a ground fault.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
Dave H M
IL
Posted: 04/02/12 07:41am Link  |  Print  |  Notify Moderator
holy mackrel
In my neck of the woods when messing with lectricity we call a 30 amp 110 circuit breakler single pole.
Wayne Dohnal
Bend, OR.
Posted: 04/02/12 09:50am Link  |  Print  |  Notify Moderator
I assume everybody answering this question has researched the local codes for the OP. Stealing from another post: "Whether your installation of a dedicated 30A receptacle outlet intended strictly for this RV classifies as an exception can ONLY be answered by your local authority (inspector, town office, etc)....they have the final say on these types of scenario's."
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/110V-30A-RV-outlet.htm
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
CA Traveler
The Western States
Posted: 04/02/12 10:09am Link  |  Print  |  Notify Moderator
Wayne, Good point.
Kiwi_too
Western, WA
Posted: 04/02/12 05:26pm Link  |  Print  |  Notify Moderator
Dave H M wrote:
holy mackrel
You are correct. I know you were making a point but wanted to help you emphasize it.
4 ALL that may not understand,
30 Amp RV Once read, be sure and click the 30-amp 120-volt RV Service link in the middle of the page.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
ktmrfs
Portland, Oregon
Posted: 04/03/12 08:13pm Link  |  Print  |  Notify Moderator
nope, thats a standard 120/240V 4 wire GFI breaker. Spec's list it as 120/240V
I'm curious about a 120V only 30A GFI
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
IECamper
Driveway
Posted: 04/03/12 09:31pm Link  |  Print  |  Notify Moderator
First question I'd ask is do you really need a 30 amp circuit? My TT lives in my driveway and is plugged into a dedicaed 20 amp circuit, simply to keep the battery charged. We don't ever use the trailer while in the driveway, or run the A/C, lights, micro's etc.
As I said, it is only plugged in to keep the battery charged, which draws only a few milliamps.
Unless you plan on running the A/C, you can probably just plug it in to a convenience outlet with little worries of tripping the breaker.
If you choose to install a 30 amp circuit, whether it needs to be of a GFI type is completely up to your local building agency. Here in California, it is not uncommon for them to require all garage outlets to be on either GFI or to be on a GFI breaker.
You never see a motorcycle parked outside of a psychiatrist's office
christopherglenn
a little over an hour from Yosemite
Posted: 04/05/12 09:36am Link  |  Print  |  Notify Moderator
Mine is plugged into a 20 at home (was easier then dragging the 50 cord in and out). I can run 1 ac, or nuke somthing without problems. I have a kill-a-watt in a outlet, so I can watch the voltage when I am on less then 50 amp service. It helps that I have a 50' 20 amp #10 extension cord. The smaller cord (larger number) the more voltage drop you will see as you load it, #10 is rated for 30 amps, #12 is 20, #14 is 15. Using an oversized cord I have minimal voltage drop.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
