RV.Net Open Roads Forum: 30 amp circuit in garage for RV - does it require a GFI?
 > 30 amp circuit in garage for RV - does it require a GFI?
Bob Landry
Austin, texas
Posted: 04/05/12 02:33pm Link  |  Print  |  Notify Moderator
There is nothing wrong with installing a double pole breaker for 30A. Actually, for marine shore power aplications, ABYC requires that all current carrying wires be broken with a C/B. That would include the neutral, and in the case of a 50A, it would require a 3 pole breaker so that both hots and neural were broken. In the case of 30A, you just need to check the plug by measuring across the
2011 Tundra 5.7L
2011 Keystone Outback 277RL
