RV.Net Open Roads Forum: pvc for sewer hose
goducks10
Keizer OR
Posted: 04/19/12 10:45am Link  |  Print  |  Notify Moderator
wally-eye wrote:
Do you drill some small holes in the pvc pipe or fence post to vent and/or let any water out or leave it sealed tight?
I have holes on the bottom the length of it.
Ron3rd
Upland, CA USA
Posted: 04/19/12 06:49pm Link  |  Print  |  Notify Moderator
Lot of posts on the subject and easy to do. Take your choice of round pvc pipe or 5" Fence post.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
JBarca
Dublin, Ohio, USA
Posted: 04/20/12 09:19pm Link  |  Print  |  Notify Moderator
I made mine a while ago before the fence post square style came along.
This is the 4" PVC one. And yes there are a series of 1/2" holes drilled along the bottom to let water out/air in. Works good and works with my fittings. Now moved to our larger camper.
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
westend
all over
Posted: 04/22/12 09:06am Link  |  Print  |  Notify Moderator
This is one of the more clever installs I've seen, great use of the "t's". I just picked up a square fence post so will be going with that type. Does the hose eventually drain completely or is there just a bit of water left in the hose at your next dump? Having never dumped and stored, I'm clueless.
'03 F-250 4x4 CC
JBarca
Dublin, Ohio, USA
Posted: 04/22/12 05:46pm Link  |  Print  |  Notify Moderator
I have a series of 1/2 drain holes in the bottom of the pipe. Before put the hose in I always drain it. I have never had a "wet" problem and no mold yuk in the pvc pipe. So it is dry enough. Been using this since 2003 and have not noticed any issues. This setup is now on the 2nd camper. I move most of the mods when we change campers.
Good luck with yours. The square fence post is good too.
John
nvreloader
Western Nevada
Posted: 04/23/12 12:46am Link  |  Print  |  Notify Moderator
If you have the Yellow Jacket Hornets around, make to breather holes 1/8" or smaller, or you'll be in for surprize when you open the lid, if your RV sits for a while, don't ask how I know! Ouch!.
Don
2010 F-350,6.4PSD, 6spd man trans,CC,SWB,SRW, Caravan camper shell,50 gal bed tank,17,000lb Husky WD hitch,Northwoods 2008 28KS Desert Fox Toy Hauler,2005 Honda 500 Rubicon ATV w/rumble seat,1 Aussie waiting,watching and ridin shotgun on the whole outfit.
Kordog
SE Wisconsin
Posted: 04/23/12 06:19am Link  |  Print  |  Notify Moderator
Ok so I want to do the 5 inch fence post mod, but cannot find the fence post longer than 48". Where is everyone buying this fence post? I have tried Menards, Home Depot, Lowes, and online. Please help!
2014 Coachman 320BHDS on order
2006 Cummins CC Dually 6 Spd
2011 Evergreen Everlite 33QB
Sold:
1996 Palomino Philly Pop-Up
2004 Kodiak 215 Hybrid
LarryJM
NoVa
Posted: 04/23/12 06:29am Link  |  Print  |  Notify Moderator
IIRC I ordered mine from HD and you should be able to order the same from Lowes and most have free shipping to your local store.
Do a search using "vinyl post cover" Lowes shows a 4 3/4 x 4 3/4 x 98 for 37.95 made by Freedom.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
Kordog
SE Wisconsin
Posted: 04/24/12 06:18am Link  |  Print  |  Notify Moderator
Thanks Larry, I did end up finding it at HD online, that was the only place I didn't look at online. I ordered it yesterday and can't wait to mod!
LarryJM
NoVa
Posted: 04/24/12 06:24am Link  |  Print  |  Notify Moderator
You're welcome and glad to help.
Larry
