RV.Net Open Roads Forum: For those of you who use a memory foam topper on a mattress
 > For those of you who use a memory foam topper on a mattress
Wrace
Seattle WA
Posted: 04/01/12 02:13pm Link  |  Print  |  Notify Moderator
Do you have much problem with it shifting position and in general making the make-the-bed and sheet changing processes more difficult? In particular I'm wondering how this works with beds that are not walk-around.
Do you put the bottom sheet right over the topper? The sheet fits over the 2-4" topper plus the mattress?
Thanks
Jack_Diane_Freedom
Milton Ontario Canada
Posted: 04/01/12 02:23pm Link  |  Print  |  Notify Moderator
We use a memory foam in the trailer and on our beds in the b&S. We put the memory foam on top of the mattress and then a quilted mattress cover over that and it does not move and it easy to make the bed. The quilted mattress cover hold it in place quite well. Very comfy and cozy.
2oldman
Pahrump
Posted: 04/01/12 02:24pm Link  |  Print  |  Notify Moderator
No, I use a mattress pad. Yes, if you buy a deep enough sheet.
301TBS
Ontario, Canada
Posted: 04/01/12 02:40pm Link  |  Print  |  Notify Moderator
Same as Jack_Dianne. Works great and love that memory foam! [emoticon]
2012 Crossroads Z1 271B
2009 F150 Scab 4x4, 4.6, 3v. 6spd. 3.73/9.75
Reese dual cam
RedRollingRoadblock
Oregon
Posted: 04/01/12 03:09pm Link  |  Print  |  Notify Moderator
Yep
gbopp
The Keystone State
Posted: 04/01/12 03:40pm Link  |  Print  |  Notify Moderator
RedRollingRoadblock wrote:
Yep
Yep, it makes a big difference.
IAMICHABOD
Sunny So Cal
Posted: 04/01/12 04:13pm Link  |  Print  |  Notify Moderator
I don't have a problem with it shifting position on my non walk around bed. I put the sheet over the 4inch foam plus mattress with no problem I also have a fitted mattress protector on top of it that helps keep it in place the sheets I have have deep pockets it was in the description when I bought them on line. It is a bit of work in a small area but not what isn't in these things [emoticon]
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
MX-RV
Dufferin County, Ontario
Posted: 04/01/12 04:18pm Link  |  Print  |  Notify Moderator
Absolutely we have a foam mattress at home no springs. The first night in the trailer neither of us slept we went right to Walmart and bought a 3" topper and deep sheets. The topper has never moved the sheets stay tucked and we sleep just like at home. The other side of that is if we have a guest or two we can place the topper on the goucho and make it tolerable and we end up with a slightly less refreshing sleep, but better than would be had with the guests up and down all night on the other bed. We learned that one the hard way too. Worth every penny. Good luck
You can take me camping, but apparently you can't make me camp!">
ANewCreation
VA
Posted: 04/01/12 04:25pm Link  |  Print  |  Notify Moderator
I just bought a quality 2 1/2" memory foam topper from QVC and put it over an air mattress and it stays put. I put the quilted mattress cover over it and the air mattress and then deep pocket sheets. It is like sleeping on a cloud.
Bob & Ann
North AL
Posted: 04/01/12 04:49pm Link  |  Print  |  Notify Moderator
We too have a memory foam topper and love it. We have had no shifting as we have a matress cover over it. It make a HUGE difference in the comfort of a standard RV matress.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17}
Chihuahua - Lola
Autumn-Red Poodle
Tiffin 2014 40 QBH Phaeton
Freightliner Chassis
Cummins ISL 380 HP/150 Torque
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2014 Jeep Wrangler Unlimited Toad
Demco Dominator & Airforce One
