RV.Net Open Roads Forum: Travel Trailers: Louvered vent door behind fridge.
 > Louvered vent door behind fridge.
jbrowning
Colorado Springs Co.
Posted: 04/01/12 02:50pm Link  |  Print  |  Notify Moderator
Hello everyone, on my 1969 Coachmen Trailer. Behind the fridge there is this louvered door.
Now I understand that is ventilation for the fridge. But I'm trying to figure out how to keep wasps and stuff from flying in there (I'm thinking a screen of some sort. And what about when it is rainy or during the winter times when I will be out camping. What can I put up to keep the cold and wind from coming in?
Thank you
Jim
jetenbu
Southeast Texas
Posted: 04/01/12 02:55pm Link  |  Print  |  Notify Moderator
I just put screen in mine. No more dirt dobber nests. I do not RV in cold or snow, I stay south. Sometimes it gets cold here in Southeast Texas but not like up north. I really do not think cold or rain will bother your frig.
Jim
RV: 2012 Montana 3625RE Quad Slide SKP#108921
TV: 2004.5 Dodge Dually 3500 HD
Favorite Quote: ''Life's tough, pilgrim, and it's even tougher if you're stupid.''-- John Wayne
Warning: THIS RIG PROTECTED BY SMITH AND WESSON!
U.S. Navy Vietnam Vet 1967-1968
jbrowning
Posted: 04/01/12 02:58pm Link  |  Print  |  Notify Moderator
How did you attach the screen to the louvered door? I was wondering about winter time and the cold air coming into the trailer and making me cold?
Thanks
Jim
Old-Biscuit
Across the USA
Posted: 04/01/12 03:00pm Link  |  Print  |  Notify Moderator
Some screen material but nothing that will stop air flow.
Winter, spring, summer, fall........air MUST flow thru there & out the top vent in order to remove 'heat' from cooling coil & supply combustion air for gas burner.
Cold wind should not be entering the inside of your rig thru that vent area. If you are getting drafts from around fridge then you need to recaulk the fridge/trim area inside the rig.
Do NOT block the air flow around back side of fridge.
jbrowning
Posted: 04/01/12 03:21pm Link  |  Print  |  Notify Moderator
Thank you. But how do I attach the screen to the metal door? I don't think I want to use any screws.
Thanks
Jim
dublittle
Posted: 04/01/12 03:26pm Link  |  Print  |  Notify Moderator
This may be 2 bad ideas, but here goes. 1. Hot glue the fiberglass screen on the back. Lay the screen on then run a bead of hot glue and push it into the screen with a putty knife while hot. 2. I have some really strong double stick tape. It might work too. Sorry that's the best I could quickly come up with.
eHoefler
ozark mountains
Posted: 04/01/12 03:30pm Link  |  Print  |  Notify Moderator
Use fiberglass screen, cut it to size, then on the back, lay a bead of sealant, I used polyurethane, then push the screen into it and through the screen. A little messy, but it works. I also did the intake screen on the water heater.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
pianotuna
Regina, SK, Canada
Hi,
Actually cold below freezing *can* damage the fridge.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Wiscampsin
Wisconsin USA
Posted: 04/01/12 03:37pm Link  |  Print  |  Notify Moderator
I used hot glue to hold aluminum screen in place. Same on the water heater vent.
2013 Palomino Sabre 34 REQS-6
http://s1340.beta.photobucket.com/user/W........6?&_suid=1357224714962013706578115184365
CincyGus
Cincinnati
Posted: 04/01/12 04:32pm Link  |  Print  |  Notify Moderator
I did it on my pop up with gorilla tape and it held the 18 months I used tha camper and was still on very good when I traded it in. A strip running around each side just like a picture frame. Make sure to clean the area very well first and then dry it or let air dry. Mine lasted from Apil 2010 until I just traded it in. I checked it beofre I traded it in thinking I would redo it but it was as strong as the day I did it so I left it alone.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
