RV.Net Open Roads Forum: Tech Issues: Tire air pressure pump?
 > Tire air pressure pump?
rmalik1
Pittsburgh,Pa.
Posted: 04/01/12 11:17pm Link  |  Print  |  Notify Moderator
Have Goodyear tires (G614) on fiver and I think the psi is around 110. Would like smallest/lightest air pressure pump capable of doing the job in a timely manner and need some recommendations?
2012 Cedar Creek 36RE w/ Level Up
B&W Turnover w/ 18k Companion Hitch
08 Ford 350 Lariat DW PSD Crew Cab Long Bed 4:30
Old-Biscuit
Across the USA
Posted: 04/01/12 11:36pm Link  |  Print  |  Notify Moderator
I have one similar to this model.......12V DC Air Compressor
My 5'vr tires are 110# also.....it will air up the tires from 90# to 105# in under 5 minutes. Small, handy.....has a case.
craig7h
Marion, Iowa
Posted: 04/02/12 04:18am Link  |  Print  |  Notify Moderator
I have a sears 110v that travels with me. I also have the g614 and have no problem with this compressor. The compressor is not the pancake style is rated for 125 psi. I will have to say to get to 110psi you have to keep the compressor running.
Craig
06 RAM 3500 diesel power
08 35' Cardinal
Jim Cindy
Northcentral, PA
Posted: 04/02/12 06:09am Link  |  Print  |  Notify Moderator
We have a Viair like this. Very similar to the clicky above. Has no problem with 110 psi.
Viair
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
Dick_B
Palos Heights, IL USA
Posted: 04/02/12 06:11am Link  |  Print  |  Notify Moderator
For previous responses you could also search this Forum for `air compressor'.
We carry a Sears 3 gallon type.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
skipnchar
Topeka or somewhere else
Posted: 04/02/12 08:29am Link  |  Print  |  Notify Moderator
It kind of depends on what YOU think a reasonable amount of time is for the job and how much air you're talking about. If you're inflating from flat then most of the small ones will take a lot of time to bring a tire to over 100 LB of pressure. If you're talking about adding 10 lb. of air then lots of small 12 volt pumps will do that job in three or four minutes time.
I carry a small "Slime" Chinese made 12 volt pump. It comes with case, 20 feet of 12 volt cord and 20 feet of air hose and has a max pressure of 150 PSI. It will add 20 PSI of air in my 245/75/17 E truck tires in about five minutes. Came from Walmart for about $35.00 or $40.00.
Good luck / Skip
I see the price is up about $10.00 now http://www.walmart.com/ip/Victor-Direct-Drive-Tire-Inflator/14324189
msiminoff
Silicon Valley, CA
Posted: 04/02/12 10:49am Link  |  Print  |  Notify Moderator
Check out the MV-50.
'04 Alpenlite Saratoga 935, 326W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins, Goerend Trans, Vision 19.5 w/XDE's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Thuren trackbar, RS9000XL/MyRide
Dusty R
Charlotte Michigan 48813
Posted: 04/02/12 01:53pm Link  |  Print  |  Notify Moderator
I like the ones that you can set to turn off when they reach the pressure you set. They are slow so you can be doing something else while it is pumping and you don't have to stand and watch it, for fear of over filling a tire.
Dusty
BrokenElbow
Valencia, CA
Posted: 04/02/12 04:38pm Link  |  Print  |  Notify Moderator
Q Industries sells their MV90 that does 110psi just fine. I have one for my G614's....no problem. I believe it's the best bang for the buck in 12v compressors around. It's very competitive with more expensive Viair units. BTW, If you know the axle weights of your unti and look at the manufacturer's load tables for the G614, you might find that you are good at 90 or 100psi. I am running 95psi in mine now.
2011 Montana 3455, MorRyde pin box, TrailerSaver BD3 air hitch, G614 tires, 2x6volt batts, 2 x Honda 2000i, Rotochoks, 6 pnt Levelup, TST TPMS, Arvika bike rack, Voyager Semi Wireless Rear Cam, Flojet Mascerator, 2008 F350 Lariat 6.4L diesel 4x4 SB CC SRW
