RV.Net Open Roads Forum: Class A Motorhomes: toliet change
 > toliet change
racer99
channahon
Posted: 04/02/12 06:10am Link  |  Print  |  Notify Moderator
1991 bounder/454/32'/p30
I am going to change out my older toliet with a upgraded one but the the holes on the new one are one the sides instead of fr & back-Anybody do this changover and how big of a deal is it--Thanks Rich
lennyjudym
naples
Posted: 04/02/12 06:18am Link  |  Print  |  Notify Moderator
once you take out the toilet should see a ring with four slots (THEN YOU WILL KNOW TO DO)same as a house.
lenny
Dutch_12078
Great Sacandaga Lake, NY
Posted: 04/02/12 07:17am Link  |  Print  |  Notify Moderator
If your flange only has two slots, remove the screws securing it to the floor, and then using a screw driver or drift punch and a hammer, try tapping on it to turn it to where you need it. Once in place, reinstall the screws. Most toilet flanges rotate around the center hub.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
rockhillmanor
On the Road
Posted: 04/02/12 08:04am Link  |  Print  |  Notify Moderator
I'll just add that you have to consider the height also 'before' you start the installation.
I took out my old one, installed the new one, no sweat!
That is until I realized the water lines did not match up because I bought a taller toilet. AND you can't find that particular water lines and connectors in hardware stores! Had to take it out, put the old one back in and head on the down the road until I found an RV store.
So before you start check if you are going to need to change the water inlet hoses so you can have the correct ones on hand. Other than the hoses it is a real simple swap out.
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
wny_pat
Western NYS
Posted: 04/02/12 09:59am Link  |  Print  |  Notify Moderator
Consider the height not just for the water lines, but for the clearance. You might not be able to open the cabinet door behind the toilet if it is to high.
Dutch_12078
Posted: 04/02/12 11:59am Link  |  Print  |  Notify Moderator
When I replaced my OEM toilet with an Aqua Magic Style Plus, I also had to extend the water line. I added an inline shut off valve, an elbow, and a foot or so of PEX tubing to the existing Quest gray tubing, all with parts off the shelf at my local Ace Hardware. Home Depot and Lowes also carry all the needed fittings and PEX tubing.
96Bounder30E
America is my home!
Posted: 04/02/12 01:03pm Link  |  Print  |  Notify Moderator
When I changed the toilet in my '96 Bounder I had the same issue.....I used a Dremel tool to make new slots in the plastic flange.....
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
racer99
channahon
Posted: 04/04/12 06:36am Link  |  Print  |  Notify Moderator
wonder what number toliet would be a straight exchange for my galaxy-trying to figure which will fit without hitting the wall or stopping drawer from opening-lots of measuring to do I guess-Rich
VinCee
Western NY State
Posted: 04/04/12 10:02am Link  |  Print  |  Notify Moderator
I called Thetford and they recommended what toilet I needed as a direct replacement to my OEM. New model is taller so I went to Home Depot with the fittings I had and they hooked me up with flex hose (like used at home) and the right couplings, everthing just hand screwed together, toilet fit original flange and good to go.
wny_pat
Western NYS
Posted: 04/04/12 11:51am Link  |  Print  |  Notify Moderator
What you can and can't swap out:
Thetford RV toilet replacement swap chart
 > toliet change
