RV.Net Open Roads Forum: has anybody bought a mitre saw from harbor freight
Open Roads Forum  >  Around the Campfire
 > has anybody bought a mitre saw from harbor freight
topflite51
In The Desert of Nevada
Posted: 04/03/12 07:28am Link  |  Print  |  Notify Moderator
My experience with tools from HF is that they are more than adequate for the average person, they are not intended for heavy duty usage. Invest in high quality, top of the line blades instead.
David
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to golf or fish
Simply Despicable
Any errors are a result of CRS.
belfert
Shoreview, MN, USA
Posted: 04/03/12 09:19am Link  |  Print  |  Notify Moderator
I personally won't buy anything with a cord or a battery at Harbor Freight. Many people have great luck, but just as many have bad look with their power tools. Sure, the store will replace the tool, but how much time are you going to waste on that and eventually the warranty will run out.
If you're trying to frame a house with their miter saw it would probably work fine. Any sort of woodworking or anything that needs accurate angles not so much.
bluck
Silver City, NM 88061 USA
Posted: 04/04/12 09:42am Link  |  Print  |  Notify Moderator
I bought the cheap miter saw from HF about 10 years ago. I think it was about $30.00 on sale. I made 32 cabinet doors for the house with it and all the angle cuts for a 16 X 32 ft. barns rafters. I don't think I could ask more from a tool. It's still going strong. I did buy a good Craftsman blade for it.
2004 Chevy.
Duramax-Allison
2004 Thor Mirage
Kawasaki Prarie 700
mowermech
Billings, MT
Posted: 04/04/12 12:46pm Link  |  Print  |  Notify Moderator
When I was working towards getting my A&P license, I bought a 3/8 capacity reversible air drill from HF. Over the next ten years, that little drill motor drilled literally thousands of holes in aircraft skins, stringers, and frames. It finally began being a little weak, especially when drilling larger than 1/4 inch (F drill), so I traded it to the Snap-On man for a Blue-Point drill motor.
It wasn't long before I was wishing I had the HF drill motor back! The Blue-Point just isn't as good as the HF unit in several ways. Size, power, Handling ease, etc. I still have the Blue-Point, because I would lose too much money if I sold it!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
christopherglenn
a little over an hour from Yosemite
Posted: 04/05/12 09:57am Link  |  Print  |  Notify Moderator
Bought one 2 years ago, the laser line never worked (more then 3 seconds), 4 months the brake failed. When you let the trigger go, it spins close to 30 seconds before finally stopping. Works fine, but a MASSIVE safety issue.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
The Texan
Cascade or Meridian, Idaho
Posted: 04/05/12 10:05am Link  |  Print  |  Notify Moderator
If you take it back and explain the safety issues to them, they will hand you a brand new saw......
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
