RV.Net Open Roads Forum: Our Norcold to Amish Built Cooling Unit Change-out
 > Our Norcold to Amish Built Cooling Unit Change-out
UnionMan354
Where We Park It!
Posted: 04/02/12 11:18am Link  |  Print  |  Notify Moderator
Thought I would share our experience replacing our failed Norcold 1200LR Cooling unit for a brand-new Amish built unit.
Our YouTube video: http://youtu.be/EyCh7aXveow?hd=1
Hope this helps others!
Robert & Shelly
2000 American Dream 40' DS
2003 Saturn LW200
Full-timing Class of 2006!
Escapees, ACC/ACA, FMCA Members
http://www.evansrvadventures.com/
P3TC
Glendale Springs, NC
Posted: 04/02/12 12:13pm Link  |  Print  |  Notify Moderator
Nice work...Thanks
Bill
1998 Monaco Diplomat
ScottG
Bothell Wa.
Posted: 04/02/12 01:51pm Link  |  Print  |  Notify Moderator
Looking good.
One thing I wonder is if the white finish lasts longer than the grey stuff they use that starts rusting within a year.
Scott, Grace and Wesly
H0NDA eu2000i
John&Joey
Some Location
Posted: 04/03/12 05:50am Link  |  Print  |  Notify Moderator
Very nicely done, thanks for the youtube.
That charring was scary.
UnionMan354
Where We Park It!
Posted: 04/03/12 08:40pm Link  |  Print  |  Notify Moderator
Thank you for the nice comments! We just hope it helps others.
Yes, the damage we found was very scary! Also the fact that I came home, smelled ammonia, ran outside remove vent cover finding it leaking and the unit was still running! No errors, beeping, just ON! My wife was sleeping in the back of the coach at the time and who know what could have happened if I didn't find it when I did.
The cooling unit we removed was the second Norcold and we KNEW there would never be another! It was a new Amish unit or go residential! So far we are very happy with our choice!
Mootpoint
Somewhere in North America enjoying the life!
Posted: 04/03/12 10:28pm Link  |  Print  |  Notify Moderator
Very interesting. I learned quite a bit from your video.
Thanks
Nothing sucks more than that moment during an argument when you realize you're wrong.
Clay Smith
Quartzsite, Az
Posted: 04/05/12 08:40am Link  |  Print  |  Notify Moderator
My cooling unit also sprung a leak on my Norcold N841 after 11 years of use. So I replaced the cooling unit at about half the cost of a new refer with an Amish cooling unit.
While the refer was out I also saw the opportunity to improve the insulation around it.
What I had found in the hardware stores was the water-heater insulation blankets that happen to measure 48" wide by 76" tall and consists of 2 inches of fiber glass with plastic on one side. I got one and cut it right down the middle and stapled each half onto the sides of the cabinet walls. Plus, being that each piece was 76 inches tall, the extra was able to be utilized above the refer. The insulation naturally fluffed out from the walls, but having the plastic protecting it, it pushed right into place when we pushed the refer back into the opening.
Also while the refer was out, I went to a sheet-metal shop, and had a piece of sheet-metal cut & bent to go onto the outside wall from the top of the outside access, to the ceiling. The width of the sheet-metal was sized so that when the sides where bent in 90 degrees, the width matched the width of the refer. And when the refer slid into place, it slid about an inch pass the edge of the sheet-metal. Then I finished out with more sheet-metal from the top-rear of the refer to the roof vent, plus the sides inside of the outside access.
ss573
Pearl, Mississippi, USA
Posted: 04/06/12 12:48pm Link  |  Print  |  Notify Moderator
I finally viewed the video. I am very impressed you took this on yourself. The fridge on our coach is a Dometic and part of the recall, which I had performed a couple of years ago. As luck would have it, the unit sprung a leak the day before we went on a two week vacation this past September. I had the unit replaced at Lazy Days but If I had know how "relatively" simple it is I might would have done it myself and saved a bunch of money.
These Amish units look to be rock solid. Congrats on a fine job!!
2004 Fleetwood Flair 31A
Workhorse W-20
'97 Ranger toad
UnionMan354
Where We Park It!
Posted: 04/07/12 08:42pm Link  |  Print  |  Notify Moderator
Wow, sounds like you did a nice job! We tried to do similar; improve the protection/insulation around it and the wall(s). Wish we had spoken to you before hand! Did you by chance take pictures that you could share?
Mote
Westport, indiana
Posted: 04/11/12 10:44am Link  |  Print  |  Notify Moderator
Did the same thing to the fridge in our old camper as when we bought it the cooling unit was rusted out. It works so good now we have a hard keeping the chocolate milk from freezing. I'm going to try one of those little fans this year to see if it helps.
1996 Dodge Ram 2500 extended cab 2wd, Indy 500 edition Cummins diesel
2002 Jayco 325 BHS
