DocData3D
Starke, FL
I had one skirt on the nose area of my 5th wheel that was a piece of junk (over the long haul) and I am replacing it with a custom made skirt. I have to remove the snaps that are on there now screwed into the fiberglass and want to plug the screw holes the best I can.
So beyond puttying the holes, what is the best way to plug and hide these holes?
Thanks,
Dave
downtheroad
Pacific Northwest
Other than putty/bondo/or fiber glass patching...then sanding and painting...I would just put a couple of dummy screws into the holes.
Make it look like they belong and forget about them.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
troll3193
SouthWest, MI USA
I a lot of times will just put a screw back in the hole with some silicone sealant...
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
ScottG
Bothell Wa.
I would use silicone but if it was a very visible location and it's on the gel-coat, I would use a filler product from a boat supply store. They have stuff that blends in almost seamlessly.
Scott, Grace and Wesly
H0NDA eu2000i
Grillmeister
BBQ TOUR USA
downtheroad wrote: Other than putty/bondo/or fiber glass patching...then sanding and painting...I would just put a couple of dummy screws into the holes.
Or maybe some stainless pop rivets?
Show me the GRILL and STAND BACK!!!!
DocData3D
Starke, FL
I'll probably see if I can find the boat repair stuff since I would prefer they be the least visible as possible.
LarryJM
NoVa
I used the plastic screw covers that pop into phillips head screws and put some double sided Eterbond on the and in the holes to seal them up.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
johntichy
The problem you will have is if you just fill the holes without feathering them out and if you do not put figerglass backing they will reappear in no time at all. Best thing you can do is put stainless steel scerws or rivets. Additionaly, if there is the slightest crack on the perimeter of the holes it will spread like wildfire. You are always much better off drilling to the next size.
mike4947
N. Syracuse, NY
Bondo has a polyester resin base. Will not stand up to water/moisture as it is hrydoscopic. The marine repair stuff folks are talking about is MarineTex. It is an epoxy based filler. Sands wonderfully holds to any surface outside of ABS and takes paint or gelcoat great as well. Not to mention waterproof.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
They say you learn by your mistakes, in that case I must be a genius.
Wherever I happen to park
TFor a small hole, like a screw hole they make a putty stick that works wonders, Of course after you really need to sand and paint for a perfect job, but you need not do a whole bunch of work to patch the hole.
If you get lucky and have a standard color rig.. You can use the body putty stick and a touch up tube to paint it.
