RV.Net Open Roads Forum: Toy Haulers: Installing Inverter in 2012 Fuzion
Search only in Toy Haulers
 > Installing Inverter in 2012 Fuzion
ccie6872
Arizona
Posted: 04/02/12 01:59pm Link  |  Print  |  Notify Moderator
I just took delivery of a 2012 Fuzion 315 and love it! The one disappoint is the need to run the generator for small items such as the TV's. I would like to install an inverter and curious if anyone just recently installed one in a late model Fuzion (or something similar). I am looking for inverter recommendation, mounting/wiring locations, etc.
2oldman
Winchester WA
Posted: 04/02/12 02:01pm Link  |  Print  |  Notify Moderator
There are so many types and ways to install them, you may want to go over to Tech and search 'inverter' and start reading. Doesn't matter if it's a toyhauler or a TC, it's pretty much the same.
smkettner
Posted: 04/02/12 07:06pm Link  |  Print  |  Notify Moderator
I power my tv, dvd, laptop and charge small items with a Go Power 300w sine wave inverter.
I mounted the inverter behind the fuse-breaker panel. 12v connects to the main battery feed to the panel. 120v is wired into the entertainment area circuit with an automatic transfer switch. The wiring is very straight forward if you have done any home wiring before. The Go Power 300w has a provision for a remote power switch so with the touch of a button I have instant power.
GP 300w SW $160
Xantrex 15 amp switch $49
So all in maybe $250-$300 for self install.
Morningstar also makes a great 300w sinewave inverter.
675 watts solar
