RV.Net Open Roads Forum: Truck Campers: Help With Camper Dimensions Please
 > Help With Camper Dimensions Please
wnjj
Cornelius, Oregon
Posted: 04/02/12 09:36pm Link  |  Print  |  Notify Moderator
Super_Dave wrote:
My guess was his 101" dimension was bumper to front pass thru window.
He did say the 101" was an "inside the bed" dimension so it's probably not to the bumper.
WuShock
Wichita, Ks.
Posted: 04/02/12 10:18pm Link  |  Print  |  Notify Moderator
Is this the correct way to measure? I did not add that rear bump out area to the 48", as it shouldnt interfere with the wheel wheels.
* This post was edited 04/02/12 10:28pm by WuShock *
AnEv942
CA
Posted: 04/02/12 11:29pm Link  |  Print  |  Notify Moderator
Nice camper, correct but the bump out would be good number to pass on as its at tail gate (on a long bed) to check against tail gate opening width. Also height from underside of nose/overhang to bottom of camper where it would sit on floor-our 01 Ford has a fairly tall cab, pretty sure Id need a platform for it.
The bed measurments your giving are good for checking against truck- but measuring INSIDE floor length would be actual camper size. Id also vote intended for long bed.
I think supplying numbers for folks to check is a good thing-but in no way would I assume responsibility for the truck someone might buy as a result of suppling them.
01 Ford 250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
recycler
michigan
Posted: 04/03/12 08:59am Link  |  Print  |  Notify Moderator
from pics it looks like a 9 footer roughly and you may want to measre width of the bump out as newer trucks had narrower tailgate openings
1968 franklin 11fk
back to my 93 cummins
kohldad
Goose Creek, SC
Posted: 04/03/12 10:26am Link  |  Print  |  Notify Moderator
Hornet made a 9'6 and a 10' version in 1987 according to NADA. To determine which, measure from the inside of the under cab window to the inside of the rear door.
The measurement along the side is correct to determine bed length. 101" is the correct length for a long bed truck. This gives a couple of extra inches to clear the truck's tail lights since they protrude past the truck bed.
When giving dimensions to a potential buyer, always mention they need to confirm the dimensions to be sure.
recycler - I think your camper is the same model as the one I grew up camping with. 5 of us in the camper was a lot of fun.
Photo Albums
2004.5 Ram 3500 4x4 Quad-Cab SRW CTD 6-spd, XD9000 winch
2004 Lance 815 (an upgrade from my prev 2005 35' fiver )
DW (homemaker), 1 DD @ Clemson in Civil Eng (Dec 2013) w/SIL, 1 DD Tech Grad (home but employed), 2 DFs (meow)
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/03/12 07:34pm Link  |  Print  |  Notify Moderator
If 101" is the length of that big red arrow you drew on the picture, then it's definitely a long bed camper.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
