MKDSK
Corinth, NY/USA
Okay I went to see if everything was good in my TT and I went to turn the fridge to test it and it just keeps clicking and it won't turn on and YES the propane tank is on and there is propane getting to the fridge. The fridge works on the electric just not with the propane...
Ka Ron
Kelowna
Have you cleaned the burner and electrode/flame sensor on the fridge?
Join Us For A Trip Down The RV Highway
jackandh2o
Golden Valley, Arizona
Did you try running the stove to make sure there isn't air in the line?
WHS
Waitsburg, Wa.
Go turn off the propane, let it sit for a bit, then reopen the valve slowly... Then go light off the stove burners for a few. Should cycle the air out, which is what I would suspect. However, as stated, it may also need to be cleaned as dirt, dust or even a spider could have gotten into the inlet and plugged it up.
HC
skip
05' Layton Lite 170LT Cascade edition
06' Chevy Silverado K1500
We-No-Nah Rendevous, a Ljutic, a Remington, a Hard Rock Pro, a Polaris 550XP & Raleigh the Hunter
MKDSK
Corinth, NY/USA
I did light the stove burners and they work fine then I tried the fridge and it still just clicks. What do I do to clean out the burner and electrode/flame sensor on the fridge?
edited 04/02/12 05:22pm by MKDSK *
bob213
Fresno, CA
How old is the trailer? Could be the ignitor or the control board. On last TT I had to replace the control board because mine just kept clicking, even after replacing ignitor, cleaning burn tube etc. If you do replace, go with a Dinosaur Board.
DE88ROX
West Michigan. The other West Coast
MKDSK wrote: Camper wasn't level. Soon as I leveled it the fridge clicked right on.
Don't you just love those cheap and easy fixes!!
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
WHS
Waitsburg, Wa.
Need a little more info at this stage...
MKDSK
Corinth, NY/USA
kearlms
Rexburg, ID
I did have a situation like this one year. I could not figure it out. Had propane and spark, but nothing. A guy from the camp site next to me came over and checked it out and told me the spark was not where it needed to be. He adjusted it and it lit right up. It was crazy, because I had spark not an eighth of an inch from where he moved it to. Just a thought.
