Bachus
Stratford, Ontario, Canada
Hi;
New trailer (pick up later this week) has 50A service. It would be nice to plug it into a 15A outlet from time to time, just to maintain battery, run fridge, etc. Do they make a 15A male to 50A female adapter? I have a 15 to 30 for the old trailer, but can't seem to find an equivalent. Help?
Dean and Tracy Bachellier
Isobel,Evelyn, and Stuart
2012 KZ Durango D355BHS quad bunk with 5 slides
HiJacker 16K double pivot slider
2011 RAM 3500 SRW Crew Cab 4X4 CTD
"It's five o'clock somewhere...."
2oldman
Winchester WA
Where have you looked?
this one has a locking adapter.. not sure what you have.
Or you can piece it together from 50-30-15.
bogart661
Canyon Country, CA
You could use one of these with your 15 to 30 adapter
2013 2WD Chevy Silverado LTZ 3500HD Crew Cab Short Bed Duramax/Allison
2001 Lakota 28 RKD 100w solar
smkettner
http://tweetys.com/50-20-adapter.aspx
675 watts solar
Brewurown
Morganton, NC
This is the one I use link
Al & Eva
2007.5 2500 Dodge 6.7
2010 Montana Mountaineer 335 RET
Bessie the Bassett (in doggie heaven 4/10/13)
Little Bit the Terrier (in doggie heaven 5/14/12)
Hickory Foothills Good Sam Chapter member
tkarvelis
Pittsburgh
K-Mart has them. I was looking at them yesterday for the plug. Bright yellow and either $22 or $29
Allworth
Orlando, FL
You are going to need a 30M-50F someday anyway. Go ahead and get one and daisy-chain them. The extra loss is negligible.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
Charlie D.
E. Texas-Orange
I have also seen the adapters at Wal-Mart. Home Depot has the adapters in the circuit breaker aisle. No wire as part of the hook up, just a small adapter
Enjoying Your Freedom?
Thank A Veteran
Native Texan
garysol
Avon Ohio
Allworth wrote: You are going to need a 30M-50F someday anyway. Go ahead and get one and daisy-chain them. The extra loss is negligible.
Thats how I used to do it but unraveling that 50a cable is such a pain in the butt. So much easier to use a 50-20 adapter and just use a extension cord.
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
