RV.Net Open Roads Forum: Looking at Purchasing Amer-Lite 239 BH. Are they ok?
 > Looking at Purchasing Amer-Lite 239 BH. Are they ok?
bailsmb
Posted: 04/02/12 06:52pm Link  |  Print  |  Notify Moderator
We are looking at trading in our Coleman Pop Up for an 2013 Gulf Stream Ameri-lite 259BH. Up until today, I had not heard of Ameri-lite, but then again, I have not been an avid rv'er/camper. Can anyone provide any info/reviews on Ameri-lite? Are they reputable, will I be making a costly mistake? Any guidance would be greatly appreciated. Thank you
steeleshark
Georgia
Posted: 04/02/12 07:42pm Link  |  Print  |  Notify Moderator
Most trailers today are close to the same in quality. What is hard is finding a good dealer. Find something you like, do some research to make sure your TV can pull the trailer and educate yourself on what makes a good deal on that make and model. I also went from a popup. Go for it!
2011 Nissan Armada SL w/Tow Package
2012 Coachmen Freedom Express (292BHDS) Liberty Edition
JiminDenver
Denver, Co
Posted: 04/02/12 08:04pm Link  |  Print  |  Notify Moderator
Last year we bought a Amerilite 25BH, the non slide version of what you are looking at. So far we love it. It's not the fanciest but everything does what it is suppose to.
We had electric for our test run and for 9 days had record setting temps near 100 degrees, the AC and fridge did fine. Then we moved up higher to another park with electric and had night time temps in the 20's. The furnace was fine and we never froze up.
After that we took it boondocking and again everything worked fine even though it was freezing every night. We pulled out the day before they got a foot of snow in the area.
I will say be prepared to get a foam topper for the queen mattress or just replace it. It's just a sheet cover over the springs and you feel every one of them.
We didn't have the option but wished we had gotten the two door fridge.
SEnd me a PM if you have any specific questions.
JinD
2007/2003 Ford Expedition
Nights camped in 2011 21
Nights camped in 2012 16
shenandoahvalley
Shenandoah Valley, Virginia
Posted: 04/02/12 08:08pm Link  |  Print  |  Notify Moderator
We had an '08 Amerilite 27BH that we bought new. Spent over 300 nights in it, pulled it approximately 15,000 miles. It held up well even with significant usage by GC. Only reason we traded was to get a bigger TT and whoever gets the Amerilite will be getting a good, solid TT. We really never had any problems other than routine maintenance items. If you like the floorplan go for it.
coolmom42
Middle Tennessee
Posted: 04/02/12 09:19pm Link  |  Print  |  Notify Moderator
We have had our Amerilite 21MB for a year. Used it for one long trip (3 weeks 4000 miles) and many short ones. We are very happy with it, have had zero problems.
The mattress is bad, get a good topper for it. Just buy a standard length and cut it off.
The only construction issue that I see is the location of the water pump in ours. It is in a very inaccessable spot between the fresh water tank and the front wall of the trailer. Whoever eventually replaces it will have a very awkward job. At that point we will move it to a better spot.
2006 Toyota Sienna
Single empty-nester in Middle TN
markandkim
Swansea, MA.
Posted: 04/03/12 04:33am Link  |  Print  |  Notify Moderator
Bought our 2010 255BH with a slide last year. We've used it alot and love it. Definately add the topper on the mattress. We added a 5.5" topper for $179.00 from rvmattresses.com. Its great. No problems to complain about so far. Best TT for the price by far!
Added a 4000w champion generator which powers everything when needed. Also spent 8 days in it in the yard following hurricane irene last summer when we were without power.
Retired Navy
2012 Ram 1500 Big Horn Hemi
2010 Amer-Lite 255BH
2004 Tracker 175 bass boat
bailsmb
Posted: 04/04/12 05:28am Link  |  Print  |  Notify Moderator
Thank you everyone for your comments. I appreciated them all.
littleluck55
Fort Thomas, KY
Posted: 04/08/12 07:56am Link  |  Print  |  Notify Moderator
I have a 2008 Amerilite 25BH and have loved it. We have had it 2 years with no problems. We put a 4" memory foam topper on the mattress. The water pump is in a bad spot and makes it hard to winterize it. Also, the low point drain took me some time to find.
Question for you Amerilite owners. My lens cover came off on my rear marker light. I can not find a part number on the remaining one anywhere. Does anyone know which lens cover part I need? I have to order online. The brake lights are optronics but don't see part numbers on them either.
aaron99
Pennsylvania
Posted: 04/08/12 01:45pm Link  |  Print  |  Notify Moderator
I purchased my Ameri Lite new in 2004. Since then I have spent over 200 nights camping in it. It has been towed nearly 10,000 miles. There were a few minor issues such as brake assemblies and a hot water heater since purchased. Nothing I consider major or out of the ordinary. It isn’t a top of line coach, but has served me very well. I can’t stress enough; preventive maintenance will keep your new Ameri Lite in tip-top shape. I have no regrets about my purchase. Two times last year I was asked if my Ameri Lite was new. I smile and say, yep in 2004
Hope this helps, and good luck!
2009 GMC Sierra 4x4 Ext. Cab
2004 AmeriLite by Gulf Stream
Tekonsha Prodigy Brake Controller
1 Rescued Bichon Frise- Louie
Delaware Valley Bichon Rescue
scottykrug
Aurora, CO
Posted: 04/09/12 07:16am Link  |  Print  |  Notify Moderator
Bought our 07 24BH used and it has worked outstanding for us.
X2 on the floorplan- if you like it and it works get it. Most of the trailers we looked at seemed to be of the same construction.
X2 on the mattress. Get a topper- you back will thank you.
2009 Ram 3500 Mega 6.7TD
2007 Amerilite Gulfstream 24BHLE
Copilot (DW) Navigator (DD) Flight Engineer (DS)
