I've read posts about a vehicle's "sweet spot" with the OP usually citing a given MPH speed such as 55, 60, etc. I suppose that is the speed that gives, in the opinion of the poster, both optimum power and gas mileage. My question is: how is that "sweet spot" determined? Of course, I can determing the speeed at which best MPG is achieved but do not know how to associate that bit of information with determining best power range. My MH is an '05 gas Itasca. Thanks for any input... Larry
My coach shifts into 6th gear at 62 mph. So, 65 is my sweet spot as I can set the cruise and stay in 6 th gear for the best fuel milage and distance covering.
John
2001 42' Foretravel U320
2007 Bornfree 24 Painted
2001 Jeep Wrangler
2007 Burgman 650 Executive
Susie and Dolly (Cavalier King Charles Spaniels)
Dolly now in our hearts and thoughts 8-27-05
Doodle a Black and Tan Cavalier
Lolly a Ruby Cavalier
Driving it is the best way, and it may vary for your conditions and driving style.
Years ago there was a big debate as our '00 Dutch Star gasser was happiest at 70-72 MPH. If I slowed down my MPG went down. Why? Because we normally were traveling in the hills of the east. Too slow and it was constently downshifting and struggling to maintain speed. Keep it up into it's torque band and it would cruise along happily, only dropping a gear when needed, then getting back into overdriver quicker.
Our current rig doesn't care. Hills, flats, whatever - the torque curve is so broad it just keeps rolling along. So on that one slowing down would give us better MPG.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
The usual "sweet spot" is the minimum speed at which you can maintain your rig in top gear. This because wind resistance goes up exponentially with speed, the Big Hill beginning at about 55, and the vehicle efficiency is best in top gear.
But this is also influenced by windy conditions, slope, engine power curve, and other things. So, for example, if you are headed into a steady 20 mph wind, you might get better mileage (and at the same time save your auto tranny having to up- and down-shift frequently) by slowing down enough to run steadily in next-to-top gear.
For my rig, 60 mph and 5th gear is best, but in the headwind case, that becomes 50 mph and 4th gear.
I drive a diesel, and both those speeds/conditions put the engine at the peak of it's torque curve. Since gas engines typically have torque peaking well above engine speeds at which you'd like to cruise, I'd just stick with the speed you determine gives you the best gas mileage. If there is a headwind, slow down, but if a tailwind, do NOT speed up.
John S. wrote: My coach shifts into 6th gear at 62 mph. So, 65 is my sweet spot as I can set the cruise and stay in 6 th gear for the best fuel milage and distance covering.
Thanks! Noticed that you have a 'furry kid' named Doodle. We too had a Poodle named Doodle (Doodle the Poodle). We lost him a couple years back but he's still in our hearts and minds too. / Larry
We had our truck dyno'ed after installing all of it's electronic and mechanical mods. Where the TQ & HP curve meet, that's the sweet spot and where I try to keep the speed & RPM's when towing. Works out it's about 59 MPH in 6th gear.
Happy camping!!! See y'all down the road!!!
USAF RETIRED. "EITHER LEAD, FOLLOW, OR GET OUTTA THE WAY"!
PULL DOGS:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT "THE SILVER FOX" PRIMARY
2000 DODGE 3500 QUAD CAB DRW CTD LARAMIE "THE ROAD TRAIN LOCOMOTIVE" BACK-UP
My "sweet spot" is between 62-65mph. I installed a tach and vacuum gauge. I looked for the highest vacuum and lowest rpm while driving down the road in OD. Mine was around 10 inches vacuum at 2500rpm and a speed of 62-65mph depending on wind direction. This also gave me an average of 9-9.5 mpg.
Not to bad for a 95 Winne 31ft, 7.4l(454) with a 4L80E transmission.
IMHO, you'd get better mileage by driving slower in 5th gear.
Sarver, PA/Crystal River, FL/Shelocta, PA · W3TLN · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2012 Honda Accord EX-L · 2008 Honda Odyssey EX-L
Bunch of variables when considering power train configurations, coach weight, towing, and the biggest the driver. I'm comfortable going down the road at about 63 MPH with puts the engine at about 2500 RPM. I hug the right hand lane and let traffic pass me. Fuel usage seems to peak, per my ScanGuage at around 8 MPG at that RPM also.
I don't get the sharp stick poking me in the back of the head by my passenger at that speed which goes back to my comfort level.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
How it is determined is basically to drive, drive at assorted speeds and if your vehicle has an engine control computer that tells you MPG.. Note the readings (Average is better than instant usually)
If not, then keep very accurate records fill to fill.
Mine follows the government guidelines, MPG from slow to 55 actually increases a bit, 55-60 is fairly stable, 60+ Makes like a rock in freefall.
