lj2654
weeki wachee, florida
I called a mobile sat guy out to check satellite system to see if it was wired correctly or not, as last owner said it all should work fine...which I know doesn't mean a thing now......haha! He even couldn't get satellite to lock on 119 for dish network. HE USED A PORTABLE DISH TO ALIGN WITH SATELLITE AND PROGRAMMED THE NEW RECEIVER. Then hooked my old winegard RM 9946 up and satellite moved all over the place but never locked on anything. he thinks circuit board for system is shot...what are good easy to set up new units..he said most domes are not that great, and suggested a tailgater which he said works with Dish network and sets up simple.....any other good reviews?
2001 Beaver Contessa Naples 40
2005 Honda CRV Toad
retired AirForce
George Beggs
Homosassa, FL.
Winegard Dish Network 1000.2 Satellite Plus Tripod
You can find them cheaper on Ebay.
George & Linda
1999 Pinnacle F53 6.8L V10
Banks Transcommand
TechWriter
On The Road
lj2654 wrote: . . .suggested a Tailgater which he said works with Dish network and sets up simple.....any other good reviews?
Yep, go with a Tailgater. It combines the best of HD portable & automajic in one.
The HD Dish portables like the 1000, 1000.2, and 1000.4 (the best of the 3 IMHO) typically require a heavy duty tripod and a decent signal strength meter to set up. By the time you purchased a dish, tripod, and meter, you've spent nearly enough to buy a Tailgater.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
Dale.Traveling
Newport News, VA
From what I know now I would not recommend a roof mount. More times than not the line of site to the satellites is blocked. Ground mounted is the way to go but depends on your mechanical abilities and patience level. I found a used stick & brick manual aim dish on eBay for $30. With a tripod and signal meter my costs are a bit less than $100. Aiming can be difficult at first. I can now get mine sighted on the satellites in about 10 minutes. Otherwise I would go with a self pointing carry out.
One thing about your system is you might need to check if the dish is configured for the service provider. My antenna has dip switches inside the dome I had to reset to work with Dish Network. You might be having the same problem. Didn't try the receiver before I checked the switch settings so I don't know what it would do if they are wrong.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
Maddawgs
central MA
I have the KingDome dual LNB (two receivers)in motion on the roof. So far it has worked great in my driveway and momentarily in one campground out of three. To many obstructions for the dome to lock onto anything. After a lot of research I found that for us unfortunate souls in the north east the bulk of the dish network satellites are out of range. I have since switched it over to the dish network eastern arc satellites (61.5, 72, 77) and it seems to work fine. I also recently bought the Wineguard CarryOut 1518 portable automatic system for when the rooftop KingDome is blocked. I set it to receive the dish network eastern arc satellites and it works great. The Wineguard is fully automatic and once set up will switch between satellites as needed. It is also fully HD compatible and will accommodate two receivers so you can watch two separate channels/tv's at the same time. It can use all sat providers (Dish, Directv, Bell). I think that the Dish Tailgater can only use the Dish satellites and connect just one receiver.
Todd
Todd, Shirley, and the "Maddawgs" min-pins Precious and Buster Brown
2011 Itasca Cambria 30C
2011 Demco KarKaddy 460SS
TST 507 RV TPMS
"if there is anything left when we are gone, then we miscalculated"
Clay L
Sioux Falls, South Dakota
Perhaps the previous owner had the dish set for Direct TV and it needs to be reset to Dish.
The manual can be downloaded HERE
It explains how to set it up for either supplier.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
sdianel
Tampa, FL
We have a TracStar (Orlando FL) and we just had our software upgraded. The sat guy (Sats2Go Houston TX) hooked up his laptop and upgraded it. We also had to replace the LNB in the dome dish once because it went bad. Might be a simple fix. What brand dome is it?
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
lj2654
The satellite tech checked the control box on the roof and its bad...so I am just gonna get a traveler for the dish. I dont use the bedroom tv, and have an outside tv that I can use by moving the receiver there easily......simplest way to get it done.......thanks for all the advice and assistance.....my todo list is shrinking getting this coach set up correctly!
lj2654
tailgater, not traveler as posted before......
