funpro
Danville, CA
Ford F250 and 27' fifth wheel. 1. Should I add air pressure before attaching my fifth wheel? or after it is attached? How do you know the best PSI to use?
When the 5th wheel is not attached I run at about 12lbs PSI.
The air helper springs are Firestones
donn0128
Pronounced Ore-gun
Hitch the loaded trailer up and inflate the air bags to just bring the truck back to level. That is if you actually need to.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
AZ T&T
Mesa, AZ
I think everyone is different. I add the air before hooking up up. I run at 45 psi and I came to that number by just trying different numbers until I zeroed in on what felt best to me.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
dubdub07
Colorado Springs
I don't air up before because it makes the hitch about 4 inches higher. I don't care if the truck is level, just the ride. I would experiment between 25-40 for your FW....for us it keeps the truck bed from bouncing a lot on rougher roads.... When I had 40 psi in them, it sure was rough. Now I run about 27psi. That is 20 pumps a side with the bike pump. Just enough to keep the weight off the overloads and give a little spring but keeps the load nice and steady. When we stop, I let the air out before I disconnect. Brings the truck down lower so the landing gear doesn't have as far to go!
2012 Montana High Country 333DB
*NEW* 2012 Dodge 3500MEGA 6.7 CTD, 2012 Jeep JK Rubicon, 2012 Durango Citadel, 2010 Harley Heritage Softail....American STEEL = American profits.
funpro
Danville, CA
Great and helpful answers I really appreciate! Thanks.
tjar66
Camarillo CA
I air up after hitched and have experimented with different amounts of air and find 25#-35# works best. I also only pump up enough to keep off the overloads.
2006 Dodge Ram 3500 Cummins
2007 Desert Fox 305j
2004 TRX 450r Mine
2005 Yamaha Raptor 350 Wife's
2006 Honda 300ex Sons
2007 Honda 250ex Daughter
wandering1
If your owners manual doesnt tell you how to use it then contact the manufacturer and ask.
HR
ford truck guy
Pennsylvania
I used to air up before hooking up.. now I know what number to run at and do it before ,,,Joe
Joe and Lori
2009 Ford F350 SD 6.4
08 Montego Bay
Hers are my pictures
tartan camper
Canandaigua, New York
I keep mine at 30lbs. I like the feel at that pressure.
Backpack to fiver...and everything in between. What a life!
2008 Sprinter Copper Canyon 293FWSLS Rear Kitchen 5th Wheel
2006 GMC 2500 HD, etc.etc.
18k Superglide
SuperDutyMan
Western PA.
ford truck guy wrote: I used to air up before hooking up.. now I know what number to run at and do it before ,,,Joe X2,35psi
2011 Palomino Sabre 31RETS,5th Wheel,Triple Slide,4000W Onan Genset
2006 Super Duty,XLT, V10, 6 Speed, 4.10, Tow Command, Tow Pkg. 4X4,Dual Exhaust,K&N,Reese 15K,Air Bags
