I measured from the ground to the top of the tire wheel well opening on the bed. Hooked up 5ver and added air to match the measured height. This keeps the truck at the original height. Keeps the front end alignment and head lights at the unloaded positions also.
Airbags are not designed to increase your load capacity. Read your instruction manual that came with them. Their only purpose is to level your vehicle once it has been loaded. I run about 15psi in mine when hitched up. It rides rough with much more than that.
B.O.
2011 Big Country 3250TS...2010 Ram CC Laramie 4wd Cummins
15k Super Glide, Firestone Ride Rite, TrailAir Tri-Glide
Michelin XPS Ribs. Just say no to Chinese tires.
Twin Cities Mn.
I have Firestone bags and run about 45 lbs with a FW with a hitch weight of 2115 lbs. The formula for these bags is 1 psi for every 50 lbs of weight-I air b4 I hook up.
