RV.Net Open Roads Forum: Travel Trailers: Thermostat wiring question.....Sorry
 > Thermostat wiring question.....Sorry
firebox700
havre de grace
Posted: 04/04/12 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone, I got it figured out. The heat works and will make sure the A/C works this weekend while were at the campground.
2012 Rockwood Signature Ultra Lite 8312SS
2008 Rockwood Roo 21SS (History)
1981 Starcraft Galaxy 2108 (its gone)
1999 Dodge Durango (Retired TT)
2006 Dodge Ram 3500 Quad Cab 4x4
ME-Jeff(73)
DW-Lori (?)
DS-Jeremy(93)
DD-Charlotte (10)
my pics!!
rgolding
Southern Illinois
Posted: 04/07/12 06:56am Link  |  Quote  |  Print  |  Notify Moderator
So can it be set up so the a/c fan is on with the heat? Thinking the ceiling circulation of the rising heat in the trailer would equalize out the temps through out the trailer.
BBdawg
Apopka, Fl
Posted: 12/01/12 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I have your answer - by mistake trial and error. I have a new Hunter 44260 digital. What the following setup is doing is causing the A/C fan (not the compressor) to come on when the heater is activated. Not what I wanted, but it is what I got! I do not know if this is good or bad for my system?? With this setup, it seems like everything is working OK, both heat and cool, but is it OK?
I Upgraded from a Duo-Therm, tstat using a Duo-therm AC with a suburban gas heater
old Duo-Therm Terminal wiring was -
7.5 volt and had a red wire connected
Cool – had a Yellow wire connected
Fur – Had a White Wire connected
Hi-Fan – had a Blue wire connected
Fan - had a Tan (or Brownish) wire connected
Gnd – had a Green wire connected
The Hunter Model 44260 (From Amazon)
is Connected as follows:
Red wire NOT Used
Yellow wire connected to “Y”
White wire connected to “W”
Green wire connected to “RC” (Rc has Jumper to Rh)
Blue wire connected to “G”
Tan wire connected to “G”
Y-1 connector left blank
I know this is WRONG! But, it is what I did get. I am still trying to figure out my correct connections, which is how I found this link.
NOW, if ANYONE can help me - I am very frustrated. I can not get my wiring to work as designed on any of the MANY diagrams I have found on line.
Can anyone tell me what I am doing wrong on the above noted wiring?
I think my white - furnace wire is OK, my Yellow Cool wire is OK.
I know my blue wire is HI-Fan, MY Tan(brownish) wire is Lo-fan and my Green wire is also Fan.
Old-Biscuit
Across the USA
Posted: 12/02/12 02:05am Link  |  Quote  |  Print  |  Notify Moderator
These are OK (White..furnace Yellow..cool Green..RC/RH
Red 7.5V.not used.....taped
Y1......not used
Both blue & tan to 'G'.......????? Should use one or other OR install a mini SPST switch so you can select either Hi Fan or Lo Fan for A/C.
I use just the Hi Fan (blue) and taped Lo Fan (tan)
On circuit board of T-stat
HG/HE switch set to 'HG"
STD---HP switch set to 'STD'
Fan switch in 'Auto'
Select HEAT.....only furnace fan should run when set point is higher than room temp
Select COOL....only A/C fan should run when set point is lower than room temp
Fan Switch to 'ON'......only A/C fan should run (Hi Fan if blue wire was used)
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
BBdawg
Apopka, Fl
Posted: 12/02/12 05:58am Link  |  Quote  |  Print  |  Notify Moderator
1st, let me clarify that my new Hunter 44260 stat uses batteries and not supposed to need power from the TT. (refers to Red wire usage or not, I think)
2nd, I am going to work on this a little later today but I have a ?? If when using a spst switch in the blue Hi-fan wire, it would be connected between the blue wire and "G" terminal, along with the "Tan-low fan wire" already connected to "G". So, when the fan is called, and the spst switch is in the hi-fan position, are not BOTH the blue wire and the tan wire both connected to the "G" terminal at the same time?
In your comment you suggest only one (blue or tan) would be connected, EITHER but not both?
I think I did try your wiring suggestion (with the exception of the "either of the blue or tan" and did not get a correct operation, but will try it again today, with much better hopes!!
3rd, I spoke to the Hunter customer Support on Friday and his final suggestion was to call an a/c-heating electrical engineer or RV A/C professional out to resolve my issue. He also told me that for the Suburban Gas, Direct Spark Ignition, the t'stat HG/HE switch should be set to HE, as it is Electric Ignition and the HG setting will cause problems down the road. (any thought there?) seems contrary to the simple gas vs electric concept?
Something so simple should not be so dang confusing!! 1,000s of pages of help on this very subject, different models but still same subject, just more confusing. Every expert very confident in their wiring plan but - none have worked correctly so far on this one.
Grrrrrrrrrr!
* This post was edited 12/02/12 08:04am by BBdawg *
