HSIKES
Wilmington,NC
I bought a webber gas grill last summer. This summer it has very little heat output. Just how do you go about cleaning the gas burner? I see a blue flame in 1/3 of the burner.
Horace & Bobbi
DRAKE - Yellow Lab (rescue dog)
2005 Fleetwood Providence 39 L; 4 slides; 350 Cat
2000 Saturn LW TOAD
2009 Buick Enclave CLX 2
Preach the gospel at all times. And if necessary.....use words.
LewMichele&Paws
At a gas station in Cowlitz County WA
Is the tank in any way different?
'06 Ford F350 V10 CC 4X4 SB auto 4.10
'01 Arctic Fox 235H (5'er)
Don't lose your head...to save a minute...you need your head...your brains are in it...Burma Shave
States visited in our RV...
Gadget Guy
Calgary
Have you checked the orifice????
fordsooperdooty
WeberQ 200 Warranty-Aluminum Castings 5-years, 2 years paint excluding fading or discoloration, Thermoplastic/Thermoset Parts 5-years excluding fading, All Remaining Parts 2-years...
AND Weber has on their WeberQ website, instructions on how to clean the burner tube safely!
AND Their customer service is great...call them!
Customer Service Line
1-800-446-1071
Or Email
support@weberstephen.com
Corkey05
Washington State
The 200 has small holes in the burner tube and they crud up pretty fast.
About one a year I take a welding tip cleaner the size of all those little holes in the burner and clean each and every one.
After cleaning the grill works like new. Takes about 15-20 minutes. A small wire bit (drill bit) used by hand would work in a pinch.
2008 HR Endeavor PDQ - Blazer 4 Down
FMCA F374292
papa peter
Ripon, CA
You might be trying to light it too soon after turning on the tank valve and/or turned the gas on too fast. There's some kind of safety device built into the grill that limits the flow of gas if you try lighting the grill too fast after turning on the gas. Try turning off the tank valve, then turn on the tank valve (slowly) and let it sit for a while (I think the manual says 15 min.) THEN turn it on and light. Good luck.
2012 Winnebago Vista 26P - 2012 Jeep Limited Jet Liberty
pacific-sun
British Columbia, Canada
I had one that did the same thing.. the way I got it to work was to peel back the label on the tank valve, under it you will see a small phillips screw, tighten it about 1/4 turn and relight it. If it's better and you still want more heat you can give it another 1/4 turn.... Do mess with the valve screw while the grille is lit!!
This also works good when you are at higher elevations...
1998 38ft Beaver Contessa DP 1 slide 330 Cat.
2002 Saturn L300 1992 Honda Goldwing 1500 SE
Big Katuna
Deland, FL
I'm gonna say its the open hose flow device in the tank. If you open the tank valve too quickly, it reduces the flow to next to nothing. As someone mentioned, have the grill valve off, then verrrrryyyy sloooowwly open the tank valve, then slowly open the grill valve.
Or you might have a bad regulater.
The flame is only a half inch tall at best.
My Kharma ran over my Dogma.
barlow46
Edgewater, FL
Are you using the compact propane bottles that screw on or using a hose hooked up to another propane source? If using an external source, make sure you are not drawing propane through two (2) regulators. If by chance you are hooked up to you coach's onboard tank, you may also be running through two regulators. If just using the compact propane bottles, then follow the advice about cleaning in the above posts.
2005 Monaco Dynasty Diamond IV 42'
04 F450, 6.0 auto, 4:30 rear; BrakeSmart; 50 gal aux.tank, 01 HR Presidential 35CKS, 3 slides, axles flipped; TrailAir Pinbox. pin weight 2760. Total gross TV and 5th: 24,060 lbs.
rr2254545
Minnesota
Sounds like the old 2 regulator problem I had until Weber help line straightened me out. I even had fitting installed by the dealer that was useless I now use a 11 lb tank that stores nicely
2012 Winnebago Journey 36M Cummins 360
131 Campgrounds since we retired in July 2009
