RV.Net Open Roads Forum: Beginning RVing: Refridgerator
 > Refridgerator
David Myles
Bovey MN
Posted: 04/03/12 07:46pm Link  |  Print  |  Notify Moderator
How easy is it to remove the electric/propane fridge? The current one is shot. Want to just replace it with a electric.
donn0128
Pronounced Ore-gun
Posted: 04/03/12 07:55pm Link  |  Print  |  Notify Moderator
Disconnect the propane line and cap it. Unplug the electricity and take maybe 6 screws out and pull it out. Not hard. How do you know it is shot? Did you get an ammonia smell?
Don,Lorri,and Charlie Bear 2016
The Other Dallas
Jackthewonderdog
United States
Posted: 04/03/12 07:59pm Link  |  Print  |  Notify Moderator
Alot better if you have two people.
Son of Norway
Denver, Colorado
Posted: 04/03/12 08:29pm Link  |  Print  |  Notify Moderator
There could be a problem depending on the size of your refrigerator and the size of your door opening. I don't know what kind of rig you have, but in my class A and some others I've heard of the refrigerator can not come out through the door. It is necessary to remove 1/2 of the windshield to take it out. Be sure to measure before you start the job. If it won't fit through the door, and you're sure that you don't want the fridge, you could always just cut the box up with a sawzall or similar tool after you take the cooling unit off the back.
Miles
* This post was edited 04/03/12 08:49pm by Son of Norway *
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
flip418
Posted: 04/03/12 08:34pm Link  |  Print  |  Notify Moderator
If you are getting an ammonia smell then most likely your cooling unit is out and the fridge has to come out anyway. A cooling unit is darn near the same price as a new fridge but can be done. I replaced one about 2 trailers ago and wasn't too bad if you have some mechanical ability.
The Thomas's
2012 Keystone Cougar 328QBS
2004 Ford F-250 PSD
Firestone Air-Rites
samsontdog
Oregon, Wash Coast summer, Yuma Az winter
Posted: 04/03/12 09:41pm Link  |  Print  |  Notify Moderator
The Wife and I did this when we were younger, just turned 70. Took the old one out and went to Lowes and picked up elect. Kind of hard picking it up over the dinenet. Had to cut out part of the cabinet etc. Looks great and works great
samsontdog">">
Gale Hawkins
Murray, KY
Posted: 04/03/12 10:50pm Link  |  Print  |  Notify Moderator
It will not be too hard.
I agree a 25 year old RV frig might be better replaced than trying to get it fixed. If you still do not have a working generator going all electric is a bit harder but is doable.
Frank&Renae
Madison, SD
Posted: 04/04/12 06:14am Link  |  Print  |  Notify Moderator
I saw a Cedar Creek Custom at a show recently that had a residential refrigerator in it. The frig runs off electric when hookups are available and off its own inverter and the batteries when not hooked up.
FWIW, the residential frig was a 16 cubic foot Whirlpool in place of the 12 cubic foot 4 door RV frig.
Frank now without Renae
KZ Montego Bay 37CKM
2007 Dodge 3500HD DDW
Three cats -- Sunkist, Topaz, & Amber
One dog -- Rascal
Started Full Timing since March 26, 2008">
michelb
Ottawa, ON, Canada
Posted: 04/04/12 06:19am Link  |  Print  |  Notify Moderator
As Miles mentioned, one of the big issues is gettting the old one out and the new one in through the door. I had planned on getting a residential in our 98 PaceArrow but the residential would not fit through the door (from memory, I think our opening is only 23"). Taking the windshield out seemed like too big of a job (although in hindsight, I probably should have done it as our replacement cooling unit appears to be dying after less than 2 years).
David Myles
Bovey MN
Posted: 04/04/12 07:38am Link  |  Print  |  Notify Moderator
Thanks for all the advice! I never thought of how I would get it out after I had it out! Luckily I just took the mesurements and it should slide right out the door. I found a freezer/fridge at Lowes that will fit perfect. I am most worried about messing with the propane lines in this process.I can rip anything out I just want to do it correctly. As far as no generator we will probably be camping at places with hook ups for now. We are having are first child in May, hence ditching the tent for a RV. The tent was a bit easier to fix but so far this project has been fun. Got the leaks fixed first then figured out the vacuum lines and the engine purrs, now the fridge ect ect ect haha!
 > Refridgerator
