patinlouisiana
Baton Rouge, La
I see there is an article in this month’s mag. about surge protectors.
How many of you have and use one?
I never get lost! Someone always tells me where to go!
2012 Prime time Tracer 230FBS Touring Edition
2010 Toyota Sequoia Limited 4X2
pasusan
PA
There's a current discussion on this issue in the TT section: Clicky
We have one that is hardwired inside the TT.
Trip Pics
"Don't let the sound of your own wheels drive you crazy." JB & GF
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
BigSur2
Hampton, VA
I didn't until recently. My dealer only sells one that runs in the $110 range. He let me have it for free since I bought an RV from him.
BigSur2
2012 Keystone Bullet 286QBS
2006 Ford F150 5.4 V8
gbopp
The Keystone State
I bought and use a portable surge protector after a nearby lightning strike caused some damage in our Southwind.
Retired Phone Man
Covington, Louisiana
I have the Progressive Industries EMS unit.
http://www.progressiveindustries.net/ems_pt30c.htm
Their are two type of protection. The basic Surge Protector which gives you protection from spikes only and the EMS unit that handles spikes but also handles high and low voltage and checks for miss-wired power.
I see they now have Lifetime warranty. Great company.
Jim
2007 Toyota Tundra SR5 Double Cab with 5.7L V8 and Tow Package.
2007 Gulf Stream Ameri-Lite 21MB
Peaches - Lhasa Apso/Mut Mix
LarryJM
NoVa
BigSur2 wrote: I didn't until recently. My dealer only sells one that runs in the $110 range. He let me have it for free since I bought an RV from him.
Unfortunately I doubt you have an EMS that not only protects against surges, but more importantly low voltage conditions which are much more common in a lot of CGs. A decent 30A EMS will run you in the $250 to $300 range.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
skipnchar
Topeka or somewhere else
I've never used one.
Frank&Renae
Madison, SD
If your RV has the “generator prep” option then you will have an Automatic Transfer Switch/Surge Suppressor built in – you will have to check to be sure.
We have the Progressive portable ones but they do not have the high/low voltage protection. We will upgrade to one with high/low voltage and surge protection in the near future.
FWIW – some protection is better than none especially with all the thunderstorms going on all over the country right now.
Frank now without Renae
KZ Montego Bay 37CKM
2007 Dodge 3500HD DDW
Three cats -- Sunkist, Topaz, & Amber
One dog -- Rascal
Started Full Timing since March 26, 2008
LarryJM
NoVa
skipnchar wrote: I've never used one.
Yea, but I've never had my house burn down or been in more than a minor fender bender car accident, but I still carry insurance for that and an EMS is no different. You don't need it until it's too late.
Larry
JRS & B
Florida/Michigan
I do not believe any surge protector will completely protect me if, for example, lightning strikes the pad mount transformer across the street from my trailer.
When lightning struck a neighbor's house there was a surge that went through the electrical feed to my house. The closest path to the ground was my A/C unit that sits about 10 feet from the meter. It melted/blew one of the connections to the A/C unit completely off , and that is some heavy guage wire.
But I have a portable surge protection unit with the high/low voltage protection. It has tripped about four times in 6 months. So it is doing its job on over voltage problems.
