Just had oil change, DEF fill, and tires rotated. I always re-check the nut torque on occasion of my 5th wheel tires, pin box nuts, axle hanger nuts, and usually find some nuts below the required torque.
After the wheels were cooled down on my truck, I checked the torque and found every nut well below what the manual suggests. 32 nuts later, properly torqued, I'm happy again. Lesson learned - always check your wheel nut torque - even if the mechanic is supposed to do it. It may avoid other problems with tires, wheels, handling, etc......
2012 3055RL Big Horn - Dexter 7000 lb axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
Any time wheel nuts are taken off, they need to be retorqued after a few hundred
miles, some times several times again
What happens is that they 'settle' down from the flexing of the wheel (yes, both
steel and their coined lug nut boss & alloys flex during rolling...more so with
more weight)
Steel wheels have a 'coined' hole, where the metal is upset to have a spring effect
on the lug nut. They flex and flex during rolling. Re-torque them till they stop
loosening.
Over tightening them will potentially both deform the stud and/or the nut so
that they will NEVER hold the reload torque again.
Alloys use different metrics to hold the nuts on. From shouldered, to tappered
to whatever (washers) they also move till it has been re-torqued often enough to
settle them in
-Ben Picture of my rig
Read your repair order and it will say to check your lug nuts or bring it back in to have them rechecked.
Don
Perrysburg Dodgeboy 2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
Chrysler the only one to pay back 100% of their loans from the Government. *The Old Car Company" still owes 1.6 billion. Is that better Chuckles
