RV.Net Open Roads Forum: Fifth-Wheels: Wheel and tire upgrade - How to complete
 > Wheel and tire upgrade - How to complete
tkarvelis
Pittsburgh
Posted: 04/04/12 01:34pm Link  |  Print  |  Notify Moderator
I am looking at upgrading my 2008 Jayco Eagle Superlight from 15" LR D tires to 16" LR E tires.
The rims on the trailer are 6 hole 225-75-15. The tires are Goodyear tires.
I am thinking about commercial TA or something like that.
so my question is how do I measure the rim. Tire Rack is showing a bolt patern. Is that the distance between 1 lug and another? What about offset? Will I have enough room between the tires?
Thanks for pointing me down the correct road.
donn0128
Pronounced Ore-gun
Posted: 04/04/12 01:42pm Link  |  Print  |  Notify Moderator
Give one of the online trailer tire and wheel people a call. Trailertireandwheel.com is one that has a wide range of nice wheels specifically for trailers. Order the wheels and then get the BFG Commercial TA from your local tire dealer. To be sure take a tape measure and measure the original tires diameter , then on the BFG web site it will show you the diameter of each size tire. Pick one that matches as close as possible and you are good to go.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
gkainz
Arvada, CO, USA
Posted: 04/04/12 01:55pm Link  |  Print  |  Notify Moderator
Here's a pretty good explanation on how to measure your trailer wheel.
http://www.wikihow.com/Know-What-Size-Trailer-Rim-You-Have
'97 Dodge 2500 CTD 4x4
'10 Keystone Laredo 245 5er
phillyg
Front Royal, VA
Posted: 04/04/12 02:17pm Link  |  Print  |  Notify Moderator
A good source for tire/wheel related questions is at e-trailer.com. They show you how to measure your lug pattern. Chances are pretty good that your 6-lug pattern is what's called a 6 on 5-1/2" pattern but you won't know till you measure it properly. Once you know that you can look for wheels with that pattern, with basically the same offset as the originals. If you have 2" or more from the back sides of your tires now to any frame/suspension component, you should be able to fit the larger wheel/tire. Can't say about room between the tires as that is dependent on how far the mfgr placed the axles, but if you've got say 4" now, I think you'd end up with about 3" left, as an example.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
BIG ALEX
ALBUQUERQUE,NM
Posted: 04/04/12 02:21pm Link  |  Print  |  Notify Moderator
YOUR BOLT PATTERN IS 6 ON 5.5 THER TIRES YOU WILL NEED WILL BE 235/85-16
retired-tech
flint mi
Posted: 04/04/12 04:52pm Link  |  Print  |  Notify Moderator
i put the 235/85-16s that came with my 16" wheels on my jayco and found plenty of room between but i will not be able to tow it becouse they hit the bodywork when the suspension moves to much, it does move around fine in the yard. i am planning to go with 215/85-16 tires on it then i will have enough clearance to the body. tirerack.com has the overall sizes listed for tires. measure from the center of the hub to the body and double for the radius that you can use.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
pritch272
Martinez, GA
Posted: 04/04/12 05:07pm Link  |  Print  |  Notify Moderator
These are the ones I bought:
Aluminum Trailer Wheel Style:
SERIES #06
Size: 16 x 7 Bolt Pattern: 6 x 5.5 Bore Size: 4.25
Load Rating: 3200 lbs @ 80 PSI Offset: 0mm
Hispec 667655
AW1612 from trailertiresandwheels.com
2007 Keystone Laredo 29RL, 2000 Ford F250 7.3 PSD, Firestone bags, Pressure Pro, 16" Michelin XPS Ribs, MorRyde Pin Box, Dexter EZ-Flex, PI EMS-HW30C, Dirt Devil CV950 Central Vacuum, 2000W AllPower by Kipor, 4000/3500W Champion C46540
tvman44
Southwest Louisiana
Posted: 04/04/12 05:24pm Link  |  Print  |  Notify Moderator
I replaced my 225/75 15D with 225/75 16E BFG Commercial TA they are exactly 1" larger in diameter and I love them, no regrets. Got my aluminum rims from shadowtrailer.com.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
jaycocamprs
Ringgold Georgia
Posted: 04/04/12 06:56pm Link  |  Print  |  Notify Moderator
I replaced the 225/75 15D with 235/85 16E BFG Commercial TA's on a 07 JayFlight 28.5. I put the springs in the lowest holes and bolted on the wheels. Ran them for 2 years till we traded trailers
2005 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Charlie D.
E. Texas-Orange
Posted: 04/05/12 07:25am Link  |  Print  |  Notify Moderator
SERIES #06
Hispec 667655
Not only a great rim but Trailertiresandwheels can quote you new tires at a competitive price. Bought 5 of these rims with BFG Comm. T/A's mounted, balanced, metal stems and delivered to a camp site 300 miles from home.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
