RV.Net Open Roads Forum: Best Route to Custer State Park (or is there one??)
Search only in Roads and Routes
Open Roads Forum  >  Roads and Routes
 > Best Route to Custer State Park (or is there one??)
NoDakAFRVr
North Dakota
Posted: 04/04/12 02:20pm Link  |  Print  |  Notify Moderator
Long time lurker, first time poster
We will be heading to Custer, SD from North Dakota in late July. I've heard the roads there can get tricky to navigate with a camper. We have a 31' BH that we'll be towing. My HOPE is to camp at Custer State Park. What's the best route to get to the Stockade South Campground? Or...IS there a good route? We'll likely be coming from the Ellsworth AFB area (stopping there to refuel a final time and pick up final groceries.
If navigating Custer State Park is a PITA for bigger tow behinds, what campgrounds do you suggest in the area?
Thanks!
~Em & Mike
Baby O
2013 Outback 250RS
2012 Keystone Premier 31BHPR
2007 Dodge Megacab 2500 Cummins
2007 GMC 1500 Sierra
<2012 many many years of tenting it!
skipnchar
Topeka or somewhere else
Posted: 04/04/12 03:36pm Link  |  Print  |  Notify Moderator
Very few roads are not good for RVs. Stay off of Iron Mountain Highway and you should be just fine. There are LOTS of warning signs when you get ON that road warning high vehicles to stay off.
Good luck / Skip
TexasShadow
Spring Branch, TX USA
Posted: 04/04/12 03:43pm Link  |  Print  |  Notify Moderator
piece of cake. go west on I 90 to highway 79 and go south to Hermosa and take 36 west to the park. Stockade south campground is on the west side of the park, but the road through the park is fine. it is a scenic highway, curvy and will have traffic on it, but just take your time and you'll get there.
the only dump station in the park is at Game Lodge campground just after you enter the park on the east side.
enjoy. it's a beautiful park.
TexasShadow
Holiday Rambler Endeavor LE/ 3126B Cat
( Sometimes ) BMW K75 on Rear Carrier
Jeep Grand Cherokee Toad
M&G aux brake system
Datastorm 3990
854 watts of solar power
Always remember you're unique, just like everyone else.
1mtnman
Colorado
Stay here and you will never look back on your decision! RafterJ
Jim Shoe
Amelia, OH
Posted: 04/04/12 04:36pm Link  |  Print  |  Notify Moderator
Take I-90W to exit 61 (Rt.16). Stay on 16 south all the way into Custer, SD. At the main intersection in town, turn left on 89/Alt16 for about 3.5 miles to Stockade Lake CG. About 50 miles from the AFB. There are shorter routes, but they tend to knock the corners off of your camper going thru tunnels BTW, Custer has grocery stores and gas stations, but not much else.
After you park the camper, then you can explore.
Here's the link to South Dakota attractions. Be sure to drive the wildlife loop in Custer SP.
Retired and visiting as much of this beautiful country as I can.
Reader1
Ohio
Posted: 04/04/12 05:50pm Link  |  Print  |  Notify Moderator
I think we went the way Jim described. The wildlife loop use to be great. Donkeys walked right up and put their heads in your window. You won't regret this trip.
NoDakAFRVr
North Dakota
Posted: 04/05/12 07:51am Link  |  Print  |  Notify Moderator
Thanks all! Hubs is active duty AF, so we'll probably literally stop into base, fill up on last minute groceries at the commissary (I imagine that would be cheaper than grocery stores near the "touristy" areas, and gas. Also thanks for the tips on the stuff to see along the way! Now if only July would hurry up and get here
NoDakAFRVr
North Dakota
Posted: 04/05/12 11:24am Link  |  Print  |  Notify Moderator
Also thanks for the RafterJ suggestion...state park is looking mighty full so we may check into that!
dieseltruckdriver
Black Hills of SD
Posted: 04/04/12 06:18pm Link  |  Print  |  Notify Moderator
The directions given will get you there, and are correct. When you get there, do NOT forget to drive through Wind Cave Nat. Park. You will see more wildlife than the wildlife loop, and you can make it an extension of the wildlife loop road.
I live in the Black Hills, and Wind Cave is our new favorite Nat. Park, since is is easier to see wildlife here than Yellowstone anymore, but there are no bears. As an interesting note, the Wind Cave bison herd has no cattle dna, but Custer State Parks does, and they are just across the fence from each other. They take that very seriously. Also, the elk in Wind Cave are typically seen on the gravel roads, more than the paved roads.
1995 F-250 7.3 Powerstroke
2000 Arctic Fox 27-5L
dieseltruckdriver
Black Hills of SD
Posted: 04/04/12 06:19pm Link  |  Print  |  Notify Moderator
Oh yeah, the truck stop at Ellsworth AFB is no longer open, but the one at exit 61 is open.
