RV.Net Open Roads Forum: Technology Corner: Dirct TV Setup Question
 > Dirct TV Setup Question
corky506
Emery SD
Posted: 04/04/12 02:32pm Link  |  Print  |  Notify Moderator
Just a quick question. We had our receiver upgraded by direct TV and now when we set up we no longer have the beeping tones for satilite strength to here. Is there a way to turn this feature on?
Retired Firefighter. 2015-3500 Ram, Black Gold, Aisin, with 4.10's dragging a 2011 36REQS Jayco Pinnacle.
Crazy Ray
Monroe,La
Posted: 04/04/12 02:37pm Link  |  Print  |  Notify Moderator
no
RET ARMY 1980,DW Donna,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4SAMS 6V,all LEDS 525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
mikestock
Vestavia Hills, AL, USA
Posted: 04/04/12 02:41pm Link  |  Print  |  Notify Moderator
Have had these type receivers for several years and haven't found any way to get them to beep.
You should get a meter.
skipnchar
Topeka or somewhere else
Posted: 04/04/12 03:34pm Link  |  Print  |  Notify Moderator
You need one of these. MUCH better than signal strength on the TV screen http://www.radioshack.com/product/index.jsp?productId=3264941
2oldman
Ephrata WA
Posted: 04/04/12 03:39pm Link  |  Print  |  Notify Moderator
Begs a question...the SD receivers had the beep. The HD ones don't. Are you saying you got a new receiver but not a new dish? Setting up HD is a new ballgame from SD.
It baffles me why DTV removed the beep. I asked them but they aren't answering.
K Charles
Connecticut
Posted: 04/04/12 03:53pm Link  |  Print  |  Notify Moderator
One satellite and you get a beep, aim at two or three satellites and you would need two or three different beeps, one beep for each satellite that you found.
2oldman
Ephrata WA
Posted: 04/04/12 04:11pm Link  |  Print  |  Notify Moderator
just having a tone for the 101 would be sufficient.
Big Katuna
Deland, FL
Posted: 04/04/12 04:26pm Link  |  Print  |  Notify Moderator
You can get them on Ebay for like $7 including shipping.
CLICKY
My Kharma ran over my Dogma.
Wherever I happen to park
Posted: 04/04/12 04:33pm Link  |  Print  |  Notify Moderator
Having used both the on-screen display, by means of a portable battery operated TV at the antenna site, and that piece of junk you recommend I fully disagree with you.
The best... Dish Network's on-screen display, or a Bird-Dog meter.
The worst.. That in-line meter
DirecTV's is not nearly as good as DISH, but it's still better than the in-line meter
BUT.. That said.. YOU absolutely need to have the on-screen display AT THE ANTENNA SITE. so I use a portable TV for that job.
Home is where I park it.
tvman44
Southwest Louisiana
Posted: 04/04/12 05:50pm Link  |  Print  |  Notify Moderator
I use the beep from the Direct receiver and turn up the volume of the TV and open the closest window and adjust for the rapid beep. piece of cake.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
© 2016 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
