RV.Net Open Roads Forum: Travel Trailers: sway bars off when backing up?
 > sway bars off when backing up?
Chromag
Posted: 04/04/12 05:26pm Link  |  Print  |  Notify Moderator
I have the Blue Ox BXW1500 and it specifically states in the manual that the bars do not have to be removed when reversing.
2012 Crossroads Z-1 271BH
2004 Nissan Armada with Blue Ox BXW1500, Prodigy P3
GHinson
Tuscaloosa, AL
I never had before my last trip, but I probably will from now on. Turning and backing wasn't a problem, but the last site we camped in caused my truck to be higher than the camper when parked. I had a heck of a time lifting my truck enough to get the bars off because my electric jack wouldn't lift it high enough. I kept having to stack things under the jack and try it again. Of course, it took three times before I had enough under there to get it to raise. I think it's just easier to take them off while parked level.
I have an equalizer hitch, by the way.
2011 Jayco Eagle Superlite 304BHK (for the wife and daughter)
1986 Holiday Rambler AlumiLite TT (for me and the boys)
2010 F250 Crew FX4 (for me!)
tomman58
Southeast Michigan
Posted: 04/04/12 05:36pm Link  |  Print  |  Notify Moderator
I had the friction bar for years and always just loosen it prior to backing up.
I've never removed the tortion bars until the jack has taken some of the pressure off.
This has worked a 100 times or more.
2008 Silverado D/A,CC 4x4 ,3.73,IBC LTZ+
2012 Jayco 322 FKS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
Lifes short enough without bitch'n about it!
coolmom42
Middle Tennessee
Posted: 04/04/12 06:24pm Link  |  Print  |  Notify Moderator
Sandia Man wrote:
For backing into sites we usually don't remove them, but not all friction based, sway control systems are built exactly the same way. It would be best to consult your owner's manual or hitch manufacturer for the most accurate advice.
I agree.
Our Equal-i-zer manual says nothing about taking them off. We never have. But we are pretty good at backing and have never been in an extremely tight turn. They do make some noise, especially when new or wet.
2006 Toyota Sienna
Single empty-nester in Middle TN
AtomicChicken
Central Louisiana
Posted: 04/04/12 06:30pm Link  |  Print  |  Notify Moderator
I always take my sway bar off just as a precaution.
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
RedRocket204
Colorado Front Range - Got Elk?
Posted: 04/04/12 05:38pm Link  |  Print  |  Notify Moderator
Got to post 7, JBarca's post, of the below linked thread. Probably the best explanation, with pictures, of when/why to remove a friction sway bar.
RV.NET - Anti-sway device
I love me some land yachting
AtomicChicken
Central Louisiana
Posted: 04/04/12 06:35pm Link  |  Print  |  Notify Moderator
That is an entire WD hitch w/ intergrated sway - OP has a sway bar attached to a basic WD hitch (such as this).
CincyGus
Cincinnati
I do when I stop to check in or just before backing into the site. I hate the noise and don't want to take a chance I'll bind them and have them be difficult to remove once in the site. Takes all of about 1 minute for me.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
donut dave
Burnett WI
Posted: 04/04/12 06:37pm Link  |  Print  |  Notify Moderator
i have an equalizer and have never taken it off before backing. never had a problem.
fla-gypsy
North Florida
Posted: 04/04/12 07:01pm Link  |  Print  |  Notify Moderator
It is amazing how difficult that some are having understanding the question. None of the "integrated" systems require you to remove anything, but they don't have sway bars either. The question is obviously referring to a friction type sway bar and all (that I have ever used) clearly stated to remove it before backing up. WD bars on the other hand do not have any such requirement.
