RV.Net Open Roads Forum: Travel Trailers: sway bars off when backing up?
 > sway bars off when backing up?
wmoses
Houston, Texas, USA
Posted: 04/04/12 07:07pm Link  |  Print  |  Notify Moderator
Fishy Old Man wrote:
Do you take off sway bars when backing up?
Will this make it easier to back into a tight spot?
Thanks.
Fishy
Depends on the backing up. If only small angles are involved then I don't remove the sway bar, otherwise it comes off. If you look at the range of extension or compression of the sway bar, you can see why it makes sense to remove it if angles greater than say 45 degrees are likely.
Regards,
Wayne
2010 Jayco Jayfeather EX-Port 17Z | Tekonsha Prodigy P3 brake controller
2010 GMC Sierra 1500 SLE 5.3L Vortec V8 6-speed with Power Pack Plus Package | Hypertech Max Energy tune
_
Chromag
Posted: 04/04/12 07:50pm Link  |  Print  |  Notify Moderator
fla-gypsy wrote:
It is amazing how difficult that some are having understanding the question. None of the "integrated" systems require you to remove anything, but they don't have sway bars either. The question is obviously referring to a friction type sway bar and all (that I have ever used) clearly stated to remove it before backing up. WD bars on the other hand do not have any such requirement.
I've had my TT for a month and this is my first time towing. Just adding my 2 cents. Guess next time I'll rethink that.
2012 Crossroads Z-1 271BH
2004 Nissan Armada with Blue Ox BXW1500, Prodigy P3
usmc616
Orange County, New York
Posted: 04/04/12 11:14pm Link  |  Print  |  Notify Moderator
When we used a friction type sway bar I never removed it when backing, never had a problem either. Now that I know you should remove it I believe I was just plain lucky.
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.
RandACampin
Kathleen, Georgia
Posted: 04/05/12 04:06am Link  |  Print  |  Notify Moderator
Never have...never had a problem.
93Cobra2771
East Tennessee
Posted: 04/05/12 07:26am Link  |  Print  |  Notify Moderator
I always took mine off - my truck has enough clearance to turn a full 90ยบ and it made me nervous. So to be safe, I went ahead and pulled it when I got out to do my site inspection.
A lot quieter that way too.
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
fla-gypsy
North Florida
Posted: 04/05/12 08:38am Link  |  Print  |  Notify Moderator
No offense intended, there are plenty of folks here with experience that will not take the time to read the question and answer it. Let me encourage you as a newbie to towing to educate yourself thoroughly on the components, how they work, and why they are needed. Understanding the principles behind them are key to towing safely.
* This post was edited 04/05/12 12:34pm by fla-gypsy *
Normondgo
Western Canada
Posted: 04/05/12 11:12pm Link  |  Print  |  Notify Moderator
Thanks.
Fishy
Exactly.
shenandoahvalley
Shenandoah Valley, Virginia
Posted: 04/06/12 05:26am Link  |  Print  |  Notify Moderator
Thanks.
Fishy
Exactly.
Common sense should prevail. I have removed the friction bar on a few occasions where we had to back at a severe angle but most of the time it stays in place until I unhook.
BossCamper
Southwestern Ontario, Canada
Posted: 04/06/12 10:44am Link  |  Print  |  Notify Moderator
I don't see the problem. Once I reach the campground, I remove them while signing in. Not a big deal at all, and no noise for the other campers. At home, I always sit for a bit on the side of the road waiting for any traffic to clear, and it's real easy to pop them off and put in the back of the TV.
In both cases I'm through with needing them, and they have to come off to unhitch anyway, so I just take them off before backing in. Does it really matter that I might be able to back in without removing them?
I don't subscribe to the attitude that "if it's possible, then I'm darn well gonna do it!"
Experience is that which you gain immediately after you actually needed it.
2011 28' Kingsport 28RLS by Gulfstream
2010 Ford F150 Supercrew
wmoses
Houston, Texas, USA
Posted: 04/06/12 12:37pm Link  |  Print  |  Notify Moderator
Well put.
