skipnchar
Topeka or somewhere else
I don't carry a SINGLE cable but two 50 foot cables, each just coiled and tied. don't see a problem and have never needed more than 100 feet.
Mootpoint
Somewhere in North America enjoying the life!
skipnchar wrote: I don't carry a SINGLE cable but two 50 foot cables, each just coiled and tied. don't see a problem and have never needed more than 100 feet.
X2
Nothing sucks more than that moment during an argument when you realize you're wrong.
mobeewan
Hampton, Va
I use an extension cord reel for my really looooonnngg one.
Wherever I happen to park
There is one special consideration with coax..
Personally, I hand coil it, no bucket, no drum just some velcro to hold it in the coil shape.. At least most of 'em. I use cord reels for the rest.
However you should, with TV coax (including sat coax) maintain a coil with an inside diamater of at least SIX INCHES. That is the only special consideration.
randallb
On the road
Mine remains connected at all times. I roll it loosely and drop it behind the power cord between the transfer switch and clamp that holds the PC to the compartment wall.
Randy
paulcardoza
Southeastern Massachusetts
X2! Love these things!
accsys wrote: I use a CordPro for most cords I use, especially for two different dual 50' coaxs.
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
I have a cord-pro or 3 too, They are VERY VERY bad for solid center conductor coax. .And not all that good for stranded center conductor coax.
I would recommend against them
WHY
You fold the cable back upon itself in the middle, Now if you go to the trouble of using hard conenctors (two right angle, and a barrel connector) and dividing your run of coax in two, then they are ok
But if you just double the cable back on itself it will damage the cable snd it may short out your receiver as well. NOT GOOD.
double clutch
1/2 of the time bellingham ; more or less
I have found that a 100 ft cord is way too much cord.
I use 3 lengths one the length of the fiver, one 1/2, and one 8-9 ft length. pick and choose on setup or combine all lengths together.
No one way is the best for coiling. I just coil up and use a small elastic cord to keep from unraveling.
GL
Don
Don and Penni and our dog Darby
2004 Dodge 3500
2010 Jayco Designer 35 RLTS
LarryJM
NoVa
I carry two 25' and one 50' and I sewed a velco strap near one end and then another that will slide along the cable directly across from the other one when coiled up. That way I only unwind what is needed. I have done the same for my water hoses and electrical cords.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
accsys
Green Cove Springs, FL
wa8yxm wrote: accsys wrote: I use a CordPro for most cords I use, especially for two different dual 50' coaxs.
WHY
John, you are right IF you wind them that way so they will pull from both ends at the same time. I don't double mine back but wind the entire reel in the same direction. That way there are no sharp bends where it crosses sides, just a continuation in the same direction.
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350
2004 Liberty Renegade 4x4 Toad
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
