NewsW
US
4x4ord wrote: filters).
If the filters are not to spec.... you heard it here first.
Oil... ditto.
Brakes.. sure.
Home Skillet
Pearland Texas
I would use OEM filters only.
I have seen lots of issues with aftermarket filters. Most of the time, they are the wrong size and let unfiltered fluids through.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
NewsW
US
Biodiesel above permitted % is a great way to void the warranty.
Turtle n Peeps
California
Quote: What say you? Have any of you experienced the wrath of Ford's Service department after installing such devices or using aftermarket parts rather than Motorcraft?
There had better be no wrath if the part is to Fords spec or better. This is for consumables like filters, oil, and the like.
outside the fire"
FishOnOne
Katy
ib516 wrote: FishOnOne wrote: Jarlaxle wrote: But even if you do, the truck is STILL a ticking time bomb, just waiting for the other shoe to drop when the HPFP fails and Ford refuses to warranty it. ANy new Ford, GM, or VW diesel is a hand grenade with the pin pulled.
You forgot to add RAM/Cummins to that list as well.
He left them out on purpose. The VW, Chevy, and Ford 6.7L all use the same Bosch CP4 series high pressure fuel pump that has been failing. The Cummins 6.7L uses a different Bosch CP3 pump that runs at lower pressures and hasn't been failing.
I believe Chrysler reported to the NHTSA about the same % of HPFP failures as GM and Ford with their current CP3 pump.
Supreme Oppressor
Grande Prairie, Alberta
Quote: There had better be no wrath if the part is to Fords spec or better. This is for consumables like filters, oil, and the like.
The problem is that many filters out there are NOT to Ford spec. The cartridge types are different creatures than the standard spin-on ones most people are used to. I'd hate to lose warranty trying to save a couple $ on a filter. Oil is different: it lists a spec in the manual that should be listed on the bottle of whatever brand you use.
Many of the early 6.0 problems, with ambulance conversions especially, was topping up the coolant with non-ford spec coolant.
2006 F350 6.0 diesel cc lb srw
2004 Jayco Jayflight 30.5BHS
stickdog
29.820224, 81.94542
Gee, Should I worry about my mud flaps!
9-11 WE WILL NEVER FORGET!
04 HitchHiker DA LS 33.5 RLTG
09 F350 CC DRW 4X4
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Dave H M
IL
I don';t know about the "new' trucks, but the Motorcraft oil filter at Wally world is the best buy also for my early 99.
SoCalDesertRider
SanDiego, CA, USA
There should be no need to run a power tuner on an engine that already makes 800 lb-ft of torque!
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
fla-gypsy
North Florida
SoCalDesertRider wrote: There should be no need to run a power tuner on an engine that already makes 800 lb-ft of torque!
A thought that is lost on a lot of diesel owners. More is better, "right"?
