RV.Net Open Roads Forum: More questions on my new F-350 Power Stroke
Search only in Tow Vehicles
 > More questions on my new F-350 Power Stroke
Page of 5
ib516
Up here!
Posted: 04/05/12 01:44pm Link  |  Print  |  Notify Moderator
FishOnOne wrote:
ib516 wrote:
FishOnOne wrote:
Jarlaxle wrote:
But even if you do, the truck is STILL a ticking time bomb, just waiting for the other shoe to drop when the HPFP fails and Ford refuses to warranty it. ANy new Ford, GM, or VW diesel is a hand grenade with the pin pulled.
You forgot to add RAM/Cummins to that list as well.
He left them out on purpose. The VW, Chevy, and Ford 6.7L all use the same Bosch CP4 series high pressure fuel pump that has been failing. The Cummins 6.7L uses a different Bosch CP3 pump that runs at lower pressures and hasn't been failing.
I believe Chrysler reported to the NHTSA about the same % of HPFP failures as GM and Ford with their current CP3 pump.
I believe you're wrong. Was Chrysler even asked to provide data to NHTSA about pump failures? How about a link to your claim? Proof? Anything?
You do know that the Duramax (2001 - 2010) used the same CP3 pump as is used on the Cummins from 2003 - 2012 right? That's 18 model years.
I frequent many diesel forums and the only complaints I've ever read about CP3s is leaks in cold weather of the fittings that feed them (GM and Cummins).
I'm really beginning to question your knowledge, and your motives for posting in many threads recently.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
ib516
Up here!
Posted: 04/05/12 01:58pm Link  |  Print  |  Notify Moderator
I just searched via Google and NHTSA's website. Not a single mention of the CP3 being investigated. Just what I thought.....
45Ricochet
North Idaho
Posted: 04/05/12 04:02pm Link  |  Print  |  Notify Moderator
Turtle n Peeps wrote:
The Cummins does not use the Bosch 4.x pump.
LOL
One of the stooges Bob.
I believe Ricatic had a MOD, a bigger Titan tank. Maybe that was his downfall. Wonder if they need certain kind of air in the tires
* This post was edited 04/05/12 04:08pm by 45Ricochet *
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
45Ricochet
North Idaho
Posted: 04/05/12 06:54pm Link  |  Print  |  Notify Moderator
Just a link for the challenged in our forum
Now I'll get to see if its related or not, I think not knowing the source.
LINK
2BLAZERS
KEIZER, OREGON
Posted: 04/05/12 04:36pm Link  |  Print  |  Notify Moderator
ParkCountry wrote:
Thanks to all who have responded to my posts concerning our new truck. Very enlightening indeed. I have begun reading all the Ford manuals that came with my truck and I am struck by one BIG thing: There sure are a lot of warnings about using only "Approved" this and that, "Motorcraft" this and that, No chips, no programmers, no lift-kits because they could void your warranty, ad nauseum. Ford even goes so far as to warn owners that if you modify your vehicle someway then remove the devices before taking the vehicle back to the dealership for service and repair, the truck's "Black Box" will betray you and you'll be damned to Hell forever... To look at Power Strokes in my neck of the woods, I dare say that an Unmodified truck is the exception rather than the rule.
What say you? Have any of you experienced the wrath of Ford's Service department after installing such devices or using aftermarket parts rather than Motorcraft?
I've never had an issue on any of my stuff. I've even had 4'' and 6'' lifter Excursions on 35'' tires. I have a ''newer'' truck, my 2011 Dodge, and has a leveling kit, bunch of extra lights, plus airbags, camper tie down stuff etc...I would not go buy a new truck, slap on a 8'' lift and 40'' tires and believe they would still honor the warranty. I have kept the engine 100% stock on all my rigs.
With what I have seen is as long as you stay away from any/all programmers and engine mods, and keep to leveling kits and maybe 35'' tires you will not have warranty issues. It will also help if you have ALL recommended services done at your local dealer if a warranty item ever comes up.
2011 Dodge Ram 3500 4*4 Black dually Laramie 4.10 gears
2011 Arctic Fox 1150 Drybath
2009 Polaris RZR w/fun parts
2011 Polaris Sportsman 550 XP EPS w/stuff
2006 Polaris Sportsman 500 w/stuff
1977 K5 Blazer 1 ton modified
2007 Toyota Camry Hybrid (her car)
FishOnOne
Katy
Posted: 04/05/12 06:12pm Link  |  Print  |  Notify Moderator
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM416309/INRL-EA11003-50102P.pdf
IB... Here's the link you requested.
Just calling a spade a spade my friend!
45Ricochet
North Idaho
Posted: 04/05/12 07:00pm Link  |  Print  |  Notify Moderator
Thats a FORD Memo you nit. Just about what I'd expect from your knowledge base. Maybe give us a real link as to the investigation on the CP.3 pump. Someone here will walk you through making a link if you need it. Can't help with finding one though
FishOnOne
Katy
LOL
LOL
One of the Pompous Windbags...AKA Dodge Boy
Weibull
Posted: 04/05/12 07:06pm Link  |  Print  |  Notify Moderator
Did anyone else find it annoying the NHTSA pdf files were scanned images rather than documents you could use a search function on for word searching?
FishOnOne
Katy
Posted: 04/05/12 07:29pm Link  |  Print  |  Notify Moderator
My archived link doesn't work that had an index with links to the manufacturers reports, but I do know that the NHTSA sent letters to six different manufacturers asking for additional information on HPFP failures.
The manufactures listed:
BMW
Chrylser
Ford
GM
Mercedes-Benz
VW
Page of 5
