RV.Net Open Roads Forum: Class A Motorhomes: Banks PowerPack Worth the money ?
 > Banks PowerPack Worth the money ?
Page of 8
JohnnyT
Goshen New York
Posted: 04/05/12 06:55pm Link  |  Print  |  Notify Moderator
This is a pretty subjective topic... There seems to be a number of opinions expressed here that do not indicate their personal experience as a qualifier for their opinions. I bought a one ton diesel truck with a banks system. The power, fuel economy is much better than its predecessor which was essentially the same truck sans the banks system.
Based on my experience if I were looking to upgrade my torque and HP I would give Banks a hard look. I think that there are alternatives that may be less expensive.
JohnnyT Moderator
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
phillyg
Front Royal, VA
Posted: 04/05/12 07:06pm Link  |  Print  |  Notify Moderator
I put the complete Banks kit on my '97 F53 460 motor and it made a huge difference in performance, but no improvement in fuel mileage. Still, was well worth the cost for my needs. If nothing else, it permanently fixes the exhaust manifold leaks caused by the original cast iron manifolds.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
johnwalkerpa1
Pennsylvania
Posted: 04/05/12 07:14pm Link  |  Print  |  Notify Moderator
On older gas engines (460, 454 or early generation V10s) there is a decent increase in power that is quite obvious. On the newer V-10s, not so much.
Ignore any claims you hear about better fuel economy...not going to happen....
Whether it's worth the money (for power) depends on how much you really need (or want) the extra power....
JohnnyT
Goshen New York
Posted: 04/05/12 07:16pm Link  |  Print  |  Notify Moderator
melvonnar wrote:
NO
Please explain your personal experience with a Banks product.
JohnnyT Moderator
JohnnyT
Goshen New York
Posted: 04/05/12 07:19pm Link  |  Print  |  Notify Moderator
Weathertodd221 wrote:
no
Please explain you personal experience with a Banks system.
RLS7201
Some Where
Posted: 04/05/12 07:36pm Link  |  Print  |  Notify Moderator
This is an Internet rumor that just won't go away.
If you check the Banks web site, you'll find the newer 30 valve V10 actually get slightly better gains than the older 20 valve engine.
Richard
Cajunco
colorado
Posted: 04/05/12 08:19pm Link  |  Print  |  Notify Moderator
My main reason is to get more torque and HP. don't care about Fuel mileage.. my other concern is with me living in Colorado and losing power at high altitudes??
1988 33ft Allegro Tiffin
Weathertodd221
FL
Posted: 04/05/12 08:23pm Link  |  Print  |  Notify Moderator
no
unimpressive mild guage steel headers that rusted terribly.
THis was on a 1997 P30 chassis.
wa_desert_rat
Central Washington State
Posted: 04/05/12 08:52pm Link  |  Print  |  Notify Moderator
Lots of opinions from people who have no experience with Banks. I bought a 36' DP which already had a Banks Stinger package installed (along with a PACBRAKE exhaust brake) on a Cummins mechanical 5.9L and I like it. I'm not sure I'd spend $2k on a 20-year-old motorhome for it but the RV clearly has plenty of power on what is rated at 230hp (for a 22,500 lb motor home).
I also appreciate the EGT and Boost gauges which give me a good idea of what kind of work the engine is really doing and allow me to moderate what I'm asking it to do if it looks like problems might arise.
My RV, almost 20 years old, is generally up to 50mph before the end of the ramp onto the freeway and seldom gets below 45mph on the hills and mountain grades which surround me here in central WA state.
If I had a choice between a coach with Banks and one without, I'd sure choose the one with the package first.
Craig
dragr1
Alabama
Posted: 04/05/12 08:01pm Link  |  Print  |  Notify Moderator
Thorley long tube headers with ceramic coating is what I went with, custom exhaust and tbichips.com "towmaster" chip-but yours is carb'd so the chip won't work.
The headers will make a huge difference.
2012 Dodge 3500 SRW Crewcab 4x4 Cummins Auto
2013 Jayco 33BHTS Travel Trailer
1985 4Runner Rockcrawler
2007 Toyota Tacoma Crew Cab TRD 4x4 284k miles work truck
2002 Lexus IS300
Page of 8
