RV.Net Open Roads Forum: How do I keep TT from freezing in storage during RV season?
 > How do I keep TT from freezing in storage during RV season?
EZRiderGrandpa
St. Louis
Posted: 04/04/12 09:49pm Link  |  Print  |  Notify Moderator
I bought our new Rockwood TT last September and will "de-winterize" it next week. In St. Louis we are mostly out of the overnight freezing temps, but we occasionally get an overnight reading below 32°F. What do you do when the forecast is for slightly below freezing temps and your TT is sitting with 350 others at an outdoor storage facility?
I have tank heaters, but will they do a better job than just turning on the propane and turn the heater on with the thermostats low? Or do I just turn on the propane water heater and hope for the best? Or maybe do all three? The undercarriage is enclosed, so there ought to be a way to keep the pipes and such from freezing for one lousy night without winterizing it all over again.
pianotuna
Regina, SK, Canada
Posted: 04/04/12 09:53pm Link  |  Print  |  Notify Moderator
Hi,
If the temperature is well above freezing during the day, there may be enough residual heat to keep the water systems from freezing. I do "blow the lines" if it is going to be below freezing for the daily high.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Bmach
Spfld, Ma
Posted: 04/04/12 10:33pm Link  |  Print  |  Notify Moderator
I wold not worry about it. For one night around freezing it should not cause any problems.
therink
Rochester
Posted: 04/04/12 11:07pm Link  |  Print  |  Notify Moderator
X2. It has been down as low as 24 for a night or two and no problems with mine.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
usmc616
Orange County, New York
Posted: 04/04/12 11:17pm Link  |  Print  |  Notify Moderator
Ensure there is no water in the lines.
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.
CarnationSailor
Carnation,WA
Posted: 04/04/12 10:08pm Link  |  Print  |  Notify Moderator
Our Keystone Cougar has an enclosed undercarriage WITH furnace ducts that pump warm air into that enclosed area. I just turn the furnace on at 50 degrees if I expect overnight temps to drop slightly below 32. No problems so far.
2011 Keystone Cougar 24RKS
2007 Cadillac Escalade
Prodigy P2 Brake Controller
HedoTravelers
Western New York
Posted: 04/04/12 11:23pm Link  |  Print  |  Notify Moderator
X3 Never had a problem if it's not an extended cold spell.
Respect,
Brent
TV ~
Searching for diesel TV, Prodigy
Rig ~
Keystone Montana 3400RL
Selling 2010 Keystone Passport 256RLS
"Wherever you go, there you are"
danoren
Where ever I Camp
Posted: 04/05/12 12:33am Link  |  Print  |  Notify Moderator
you can leave the hot tab open a bit.
F-350 ,2006,XLT,SD,LB,EC,6.0LT,Auto,SRW.
5W Cruiser 2006 CF29CK Crossroad
RVing 4-5 months every summer since 2002.
P.A,Good Sam,TomTom GO720
Website
EZRiderGrandpa
St. Louis
Posted: 04/05/12 08:54am Link  |  Print  |  Notify Moderator
Thank you all so very much! Based on what you all wrote, I think I'll be fine leaving it alone for the occasional one night dip into the mid to upper '20's overnight as long as it gets at least into the '50's during the day. It seems that if there will be a cold snap lasting several days with lows in the '20's and highs only in the '30's or '40's the safe bet is to turn on the propane-fired heater at around 50°, which in my case has several vents in the floor. If the battery dies I can always take it home and charge it or let my truck and/or the next campsite's electric charge it.
Thanks again! You folks are the best!
christopherglenn
a little over an hour from Yosemite
Posted: 04/05/12 08:36am Link  |  Print  |  Notify Moderator
Water takes time to freeze, if it is only below 32 for 2 or 3 hours, and in the 50's during the day, I would just dump the freshwater, open the low point drains, and run the pump dry. If you are really worried b low out the lines with compressed air. The tanks will take many hours to freeze solid, slush won't hurt anything. You won't get more then a few days on the heater before the batteries are dead.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
