RV.Net Open Roads Forum: Class A Motorhomes: Residential Refrigerator
 > Residential Refrigerator
bigguyracing
Clearlake Oaks
Posted: 04/05/12 12:14am Link  |  Print  |  Notify Moderator
There has been a lot of post lately about residential refrigerators and wether they allow you to dry camp etc. What I want to know is how the heck do you get the fridge in the rv ? The tape measure doesen't lye and there is no way a residential fridge will go through the door and into the kitchen if my class A gasser ! The only way I could get one in would be to remove the slide and who is going to do that ?
slemnah
none
It can be done by removing a window or the windshield.
Golden_HVAC
Fulltime, CA, USA
Posted: 04/05/12 12:31am Link  |  Print  |  Notify Moderator
Hi,
Usually the side window is large enough to get the refrigerator into the RV. Same way the old refrigerator has to come out.
Also remember that a more expensive sine wave inverter/charge is required, not the low cost modified sine wave inverters that do not support running a high torque compressor motor.
6 batteries will store enough power, and in my case I would want about 600 - 800 watts of solar panels on the roof! That will both recharge the battery during the day, and provide most of the refrigerator's power needs during the day. Nights still might require running the generator a bit though.
Fred.
Aridon
SE Florida
Posted: 04/05/12 01:29am Link  |  Print  |  Notify Moderator
We got our counter depth through our entrance door. took the door of the fridge and the door off the RV and slid her in. tightest spot was the space between the dash and cabinets over the drivers head. Otherwise a window or windshield works.
2008 Newmar 4330 (Modified)
kdk
usa
Posted: 04/05/12 01:57am Link  |  Print  |  Notify Moderator
Sansung has said their refers will run OK on a modified sine wave inverter and will not void the warranty when installing in an RV. I will install a dedicated inverter anyway just to be safe but again not required when I install mine this summer. A counter depth will fit through the side door or through the drivers side window with no problem. Also I saw many different manufacturers of refers (Maytag, Frigidaire,GE,LG and Whirlpool) installed as OEM equipment at the Tampa RV show. I'm sure they all did not have dedicated pure sine wave inverters, may be wrong I was once before.
Blessings from a mission trip in Mozambique Africa!
kdk
* This post was edited 04/05/12 02:04am by kdk *
06 Holiday Rambler Ambassador
11 Buick Lacross
Larry Cohen
Mobile, AL
Posted: 04/05/12 06:07am Link  |  Print  |  Notify Moderator
My 22CF Whirlpool just BARELY fit through my largest side window opening after removing the window....another 1/32" and we would have to remove the overhead cabinets that were partially blocking the hole...Custom Rv in Red Bay AL did a super job and I'd do it again in a second!!
2006 Mountain Aire 43
Short haired wife, long haired daschund and 3 sugar gliders are co-pilots, along with Garmin Nuvi 855
05 Honda Pilot with Air Force One supplemental brake
Blue Ox Aventa II towbar
Whirlpool Residential Fridge !!!
The Texan
Meridian, Idaho
Posted: 04/05/12 06:39am Link  |  Print  |  Notify Moderator
We just ordered a counter depth Samsung, which will BOTH, fit through the door and operate on a modified sine wave inverter. According to my tape the Norcold will also fit through the door going out, so we will see. We have a 2.5kw Magnum MSW inverter which will operate everything with ease.
The Samsung weighs less than the Norcold and also uses less electricity, so it does make a good boondock fridge.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
Rich D.
New England
Posted: 04/05/12 08:43am Link  |  Print  |  Notify Moderator
While some refrigerators will run fine on MSW inverter power, check the current draw as compared to the same model on a PSW inverter. You will see that the one running on PSW power has a draw considerably lower than when running on MSW. This may be a consideration when sizing battery banks or if you boondock extensively. If you are changing over, it may be much less expensive to add a 1000 - 1500 watt PSW inverter dedicated to the refrigertator and keep your old MSW in place. When you upgrade your electronics in the future you can also run those from the PSW unit as some new electronics don't like MSW power.
Rich D. Wanderlodge M450 LXi
Ivylog
Blairsville, Ga. USA
Posted: 04/05/12 09:12am Link  |  Print  |  Notify Moderator
You gain atleast 10% power savings if you run one on a PSW inverter. I would want two systems for this reason and to decrease your recharge time. Even without a home refer I have to run my generator several hours/day to keep up with other power uses so I would want a second seperater battery bank and inverter/charger so I would not increase the generator run time. BUT, I decided to go with a Amish cooling unit in my Norcold as a PSW inverter/charger capable of 100 amps charging is more $'s than a new cooling unit.
I would not shy away from a unit that came from the factory with two battery banks, two inverter/charger (one a PSW) and a home refer.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
