FishOnOne
Katy
I higly recommend them. They really help from preventig leafs and debris from building up on top of the slide out.
Mile High
Denver, CO
Whats the score now ?
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
NC Hauler
Asheville NC
Mile High wrote: Whats the score now  ?
....may not be decided until the bottom of the 9th
Jim & Kathy
2013 Dodge 3500DRW Longhorn 4X4/CC/LB/Aisin tranny/4:10/Cummins: 385HP/850TQ
06 HR Presidential Suite 37RLQ/ 4 slide/ dual pane windows/Winegard SK3005 Satellite/Splendide XC2100 W/D
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
Pat Anderson
Fall City, WA / Birch Bay, WA
Well, we sure got us a mixed bag of opinions, that's for sure!
Pat & Patty Anderson
Will retire 12-31-13
2011 Fox Mountain 265RL (Fall City, WA)
1991 Alpenlite 25+2 (Omak, WA)
1993 Ford F250
2005 C-Dory CD25 Cruiser, planning to do Great Loop!
2008 Lambretta UNO150 Scooter
1987 Honda Sprees (matched set)
Our blog
dezolen
Ontario
Never had them on the 3 trailers we have owned and never missed them. Just another item that needs maintenance. Cleaning my awning is a pita. Sure don't need more to look after and I see no reason they would not be magnets for mildue.
Takes 2 minutes to sweep any debris off slide roofs.
NC Hauler
Asheville NC
dezolen wrote: Never had them on the 3 trailers we have owned and never missed them. Just another item that needs maintenance. Cleaning my awning is a pita. Sure don't need more to look after and I see no reason they would not be magnets for mildue.
It REALLY isn't that hard to miss something you've never had . Again, depending on the type of material ones slide toppers and awnings are made out of may determine how long they will last and how much maint. is needed to keep them in good shape. I've owned TT's and 5er's without slide toppers and been camping where I had to wipe water off the top before I could break camp and/or remove pine needles and leaves....never had to do this with the toppers. Then again, I've never done anything to maintain my toppers except to wipe them off on ocassion with a mop, then let them dry in the sun..and made sure the tension is still ok..in other words, have never put more than 30 minutes in maintaining all 4 slide toppers...
As I stated earlier, as well as several others...depends on the type material that one uses to cover their slides with...mine is a weave type material, and is very, very low maint and after 6 yrs since this unit was built, has held up exceptionally well...
larry barnhart
wenatchee. wa usa
Pat Anderson wrote: Did a search here, not a lot about slideout awnings. One said would not do again, a couple said would not be without them.
We were quoted about $600 for this option, did not get at time of purchase, but really are thinking we want to go back and have it installed (we only have one slideout).
Feedback?
Thanks!
I did not read any answers but will tell you we had one once but never again because of wind making too much noise.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
Mile High
Denver, CO
In high winds I have watched them billow and tip in the top of the slide breaking the top seal of the slide momentarily. Scared a fellow camper to death when a glass of water spilled on the table and a whoosh of wind came in through the top seal. I helped her move some furniture so she could pull in the slides till it calmed down a little - and she spent some time with us.
I think region is important - wind gusts in CO and NE typically mean up to 100 mph, not the 60 mph you see at the coasts. Plenty of folks have them here, and plenty of folks go home with them torn and broken. At the same time, they may appreciate them in the mountains. To me, the gain aint worth the pain.
campinrooter
Middletown,Ohio
Done it both ways would'nt be without em!!!!!!!
dannytas
Pioneer, CA
I like them. Need to install on the new trailer. It does get a little dirty between the roof and the awning. I just spray it down with the hose when I wash the trailer. Remember it's already water tight. I've even rolled them up with frozen water on top, it just rolls off. Never had a problem. To each their own, though!!!
1994 Coleman Destiny Cedar XL
1989 Fleetwood Terry Lite
DW-Lynn
BigDog-Kelley
LittleDog-Kroozer
