RV.Net Open Roads Forum: Fifth-Wheels: Pack wheel bearing on fifth wheel
 > Pack wheel bearing on fifth wheel
priestlake
Spokane, Washington
Posted: 04/05/12 08:31am Link  |  Print  |  Notify Moderator
We packed the wheel bearings in September 2011 have traveled approximately 8000 since. They say once a year, but would it be prudent to pack them now?
donn0128
Pronounced Ore-gun
Posted: 04/05/12 08:43am Link  |  Print  |  Notify Moderator
Yes.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Supreme Oppressor
Grande Prairie, Alberta
Posted: 04/05/12 08:46am Link  |  Print  |  Notify Moderator
Easier packing them now that replacing them on the highway. Brakes should be inspected annually anyways.
2006 F350 6.0 diesel cc lb srw
2004 Jayco Jayflight 30.5BHS
ScottG
Bothell Wa.
Posted: 04/05/12 09:06am Link  |  Print  |  Notify Moderator
No, the yearly thing is just a CYA thing. The reality is they will go many times that long if they were done correctly in the first place. I went about 40K and when I did them they were still perfect and didn't need to be greased.
They're no different from the front wheel bearing on rear wheel drive cars and they go between brake jobs w/o greasing.
I would left each wheel and verify brake adjustment along with making sure there is no bearing noise or play.
Scott, Grace and Wesly
H0NDA eu2000i
chuggs
Posted: 04/05/12 09:13am Link  |  Print  |  Notify Moderator
It's called PREVENTIVE maintenance for a reason.
Mile High
Denver, CO
Posted: 04/05/12 09:19am Link  |  Print  |  Notify Moderator
X2 good enough, unless you back yours in the water like a boat.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
Ozlander
Rose Hill, Kansas
Posted: 04/05/12 09:25am Link  |  Print  |  Notify Moderator
X3
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
majorloser
Central Florida
Posted: 04/05/12 09:35am Link  |  Print  |  Notify Moderator
I'd have to agree. The bearing really don't need to be repacked that often, but just the idea that you are removing the tire and inspecting the running gear on a regular basis makes it worth the effort. It's the same reason for using an infrared thermometer to monitor your tires and wheel hubs at every stop.
It's always easier to find a problem before it becomes an emergency.
2010 Ram 2500 Megacab Laramie w/Cummins
Firestone R4Tech rear suspension
Pullrite SuperGlide 18K w/ Bedsaver
2012 KZ Durango 1500 D295CS
bpounds
Whittier CA
Posted: 04/05/12 09:39am Link  |  Print  |  Notify Moderator
X3
x4
But, if you've got time and inclination, it won't hurt to do it.
Most front bearings on 2WD cars get done when the brakes are rebuilt, if even then.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Chuck&Gail
In the Colorado Mountains
Posted: 04/05/12 01:59pm Link  |  Print  |  Notify Moderator
I have Ez-Lube, so I pump as few pumps in three hubs once a year. I then take one hub open to check brakes, and hand repack. Thus each hub gets repacked once every five years. Works great for us. We do 8000 to 9000 miles a year.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
