RV.Net Open Roads Forum: Around the Campfire: E-15, pay attention at the pump...
Open Roads Forum  >  Around the Campfire
 > E-15, pay attention at the pump...
Wherever I happen to park
Posted: 04/08/12 01:16pm Link  |  Print  |  Notify Moderator
That may be.. When I was working for the chain saw place I tore the carb apart on one, Cleaned and renewed it (Standard carb kit) filled it with 2-Cycle, sharpened the chain, properly installed it, Put oil in the chain oiler, took it out to test it, Got half way through the log and it threw a rod.
Ran perfectly.... Right up to when it threw the rod.
Mercury ran the engines for 300 hours, THEN they tore them down and inspected them.
Have you "no problems" torn your engines down and subjected the parts to metallurgical testing as Mercury did?
This is why I believe Mercury.
I also note they would not profit from falsifying the report. Or at least I can see no way for them to profit from a false report.
Jarlaxle
New England
Posted: 04/08/12 03:25pm Link  |  Print  |  Notify Moderator
The hour meter on my genset stopped long before I got it...it shows something over 2500 hours. It's probably run close to 7-800 since I got it. It runs perfectly, I have no reason to tear it down. In the summer, it's running flat-out to power the A/C.
John and Elizabeth (Liz), with 3 nutty cats
My beloved St. Bernard, Marm, lost him 1/2/12
Current rig:
1992 International Genesis school bus conversion
traxtermax
UPSTATE NEW YORK
Posted: 04/17/12 06:02pm Link  |  Print  |  Notify Moderator
Maybe this will float (or sink) your boat.
down home
south
Posted: 04/08/12 04:17pm Link  |  Print  |  Notify Moderator
Everyone, around here has at least one story of failed outboards, mowers, or especially two cycle powered tools from ethanol.
They are not corn farmers and aren't biased because of it.
I threw away a blower, and two trimmers, over the last four years.
The repair place showed me the damages on the trimmers, and blower.
I don't use ethanol. I still can ethanol free gas at a couple of stations.
The pickup doesn't like it either. It's 8 years old and eng mgt doesn't like to adjust to the junk.Ethanol wasn't mandated then.
pkunk
Questa, NM
Posted: 04/18/12 08:52am Link  |  Print  |  Notify Moderator
I have an old (c.1976) Husqvarna chainsaw that had worked perfectly up until E10 was all I could get. All the fuel lines & carb gaskets just melted. Parts are almost impossible to find so essentially that gas has ruined a perfectly good tool that requires me to buy a new one at approx $500.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
atreis
IN
Posted: 04/18/12 06:13pm Link  |  Print  |  Notify Moderator
That post would be a lot more useful if they defined "older". For some of them (hoses, fuel filter bowl) they do, or provide helpful information about how to identify them. For most they just say "older" without any indication as to whether it's 10 years, 20 years, or 40 years that they're considering "old".
2009 Trail-Sport TS21RBH
2008 Toyota Sienna
traxtermax
UPSTATE NEW YORK
Posted: 04/18/12 11:10pm Link  |  Print  |  Notify Moderator
Re-read the article and the links again. They refer several times to dates or descriptions of "problem materials" not necessarily directly related to dates.
armyeng
Yelm Wa
Posted: 04/19/12 01:40am Link  |  Print  |  Notify Moderator
"The majority of complaints concern older outboard motors, those made before about 1990. BoatUS’ Seaworthy magazine asked Mercury Marine’s "
atreis
IN
Posted: 04/19/12 04:01pm Link  |  Print  |  Notify Moderator
So, if I have one that was made IN 1990, is that "about" 1990, or not? And which problem(s) is it likely to have?
Since it's put out by Mercury Marine, one would think they would know how they made their engines in particular years, and precisely when they stopped using the problem materials for each of the problems listed.
* This post was edited 04/19/12 04:21pm by an administrator/moderator *
