RV.Net Open Roads Forum: Tech Issues: inverter
 > inverter
MrWizard
Traveling
Posted: 04/10/12 09:17pm Link  |  Print  |  Notify Moderator
your looking at the "remote" switch panel
do you know where the inverter is loacted ?
storage bay, under the bed ? under a closet or the fridge ?
can you get any model numbers from the front or rear face plate
it would help greatly
also full model number description of your rexall
another member might have info regarding options & equipment
are your 12v lights, water pump, fridge etc.. still working ?
iF so then the batteries are being charged
this could be a stand alone inverter
or
a combo charger/inverter with the transfer switch/relay stuck so it does not go to inverter mode
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
BajaLinda
Full timing
Posted: 04/11/12 10:40am Link  |  Print  |  Notify Moderator
or
Storage bay, Its called a Freedom 458 series combi inverter charger. model number 20 part No.81-2010-12 Rexall Airbus. I don't think the unit came with the mh. 1st owner had it installed. 12v working. Hope this helps. Let me know if you need more and I will try to find it. Thank you very much..Linda
beemerphile1
I'm 57, I'm not a
Posted: 04/11/12 11:21am Link  |  Print  |  Notify Moderator
I still say your battery connections are incorrect. A cable was left disconnected when the new batteries were installed.
- Soren Kierkegaard
 > inverter
