RV.Net Open Roads Forum: Truck Campers: Hitch question, will this work?
 > Hitch question, will this work?
nycsteve
NY
Posted: 04/05/12 02:42pm Link  |  Print  |  Notify Moderator
Heres a hitch question, I want to use a motorcycle carrier, hitch mounted with a 50” tube . The distance to the bike from the hitch pin will be 47” . I need the distance to be able to use the door. The weight of the scooter and carrier will bea little less than 400#s. The hitch is rated at 600#s tongue weight. Does distance added from hitch translate to more tongue weight, like leverage? Heres a pic of the hitch tag.
82corvette
Southeast Nebraska
Posted: 04/05/12 03:15pm Link  |  Print  |  Notify Moderator
Yes you will have quite a bit of leverage & it will affect the way you truck handles. I would worry about the scooter bouncing too much.
kohldad
Goose Creek, SC
Posted: 04/05/12 03:17pm Link  |  Print  |  Notify Moderator
Yes, the leverage will be a huge factor and will NOT work. Just too much weight that far back.
To give you an idea in extremely simple stationary (static) terms, figure 600# @ 12" is 7,200 in/pounds of torque. So, 400# @ 47" is 18,800 in/pounds of torque which is more than twice. I wouldn't feel save exceeding 1.5 times the designed load. And this is not taking into account the weight rating and torque applied to the hitch. Usually, the hitch is only rated for 500# tongue weight (figured based on a standard 12" insert), above which you must usse an equilizer hitch which counter acts the additional torque with springs.
Of course, if we add in the motion (dynamics) from the truck bouncing down the road causing the long extension to bounce greatly, you would be looking more at 10 times the rating.
What you could do, if make a light weight trailer that is fastened to your rear hitch in two places and two swival wheels to provide the support. Or, bing the scooter in next to the camper with a slide/pivot mechanism to allow the scooter to be easily moved out of the way.
Photo Albums
2004.5 Ram 3500 4x4 Quad-Cab SRW CTD 6-spd, XD9000 winch
2004 Lance 815 (an upgrade from my prev 2005 35' fiver )
DW (homemaker), 1 DD @ Clemson in Civil Eng (Dec 2013) w/SIL, 1 DD Tech Grad (home but employed), 2 DFs (meow)
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/05/12 03:47pm Link  |  Print  |  Notify Moderator
You don't have enough hitch to do what you're trying to do.
Either upgrade the receiver to a super heavy duty class V model, or carry the motorcycle on the front hitch, or carry the motorcycle on a trailer, or eliminate the door-opening requirement and carry the motorcycle snug up to the back of the camper.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
Reelescape1
Charleston
Posted: 04/05/12 04:18pm Link  |  Print  |  Notify Moderator
There is a calc tool somewhere on here if you search
Photog101
Garden City, Michigan
Posted: 04/05/12 10:06pm Link  |  Print  |  Notify Moderator
I too have been looking for that calculator, and have not found it. Can someone please post it?????
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
tuna fisher
joshua tree ,ca.
Posted: 04/06/12 06:12am Link  |  Print  |  Notify Moderator
I'd try a front mount if your scooter weight is under 400. That's where I carry my bike and really like it,plus very little bounce. Helps with weight distribution too. JMO
  • 2001 GMC Durmax
  • 2006 Wells Cargo
  • 1986 Honda CT110 Trail
  • 75' Honda CT90 1995 8'6" Lance Lite
26'Nomad 5th wheel
ticki2
NH
Posted: 04/06/12 07:15am Link  |  Print  |  Notify Moderator
It's in TC University under Towing/hitch extension.
'68 Avion C-11
'02 GMC DRW D/A
bjbear
Cold Lake, AB, Can
Posted: 04/06/12 09:45am Link  |  Print  |  Notify Moderator
There are 2 calculators at:
Can my truck carry this camper??
Hitch Extension Calculator
03 Dodge 3500 DRW
Edge, Pacbrake, Banks Air
ATS Billet Trans, Viscous drive Torque Conv.
08 Corsair Excella 1050 Camper, 200W solar
09 Blazer 20' Covered Trailer
Stehl Car Dolly (Toad 05 Mini Conv)
48 Willys CJ2A & 74 Jeep CJ5
