RV.Net Open Roads Forum: New PSD engine coolant lasted only 14K miles?
Search only in Tow Vehicles
 > New PSD engine coolant lasted only 14K miles?
1jeep
acushnet ma.
Posted: 04/06/12 06:34am Link  |  Print  |  Notify Moderator
Sorry, im not a ford tech, i can only relay what i was told as i was also told the coolant did change completley from 2010 too 2011/12.
2011 F250 CC LB, 6.7 urine injection
2007 keystone Outback Sydney 32BHDS
2009 HD Ultra CVO
2013 CanAm Outlander 1000
1963 Wife..no mods
rexlion
Broken Arrow OK
Posted: 04/06/12 07:27am Link  |  Print  |  Notify Moderator
My buddy says, "They did say they tested it and the pH level was off...that 2.5 gallons needed to be replaced to equalize it again."
This is a 2012 PSD truck. I wonder, is Ford giving its diesels different coolant than what their gassers are getting? If not, it makes me leery of new Fords in general.
I bought a '96 Windstar and a '00 Mountaineer from this place; they're 5 miles from my house. But they've undergone 4 ownership changes since that Windstar purchase. A guy named Matthews owns it now.
* This post was edited 04/06/12 07:38am by rexlion *
FishOnOne
Katy
Posted: 04/06/12 08:40am Link  |  Print  |  Notify Moderator
Ford uses the same coolant in both their diesels and gas engines.
ib516
Up here!
Posted: 04/06/12 09:42am Link  |  Print  |  Notify Moderator
I havent heard of this with the 2011+ Cummins...anyone know if they use the same type of
coolant?
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
LarryJM
NoVa
Posted: 04/06/12 09:49am Link  |  Print  |  Notify Moderator
O.K. I really didn't know as I previously stated, but did pop over to TDS and did a quick search in the 2011/12 forum and found the following:
CLICKY
Looks like the 2011 and up Fords take a lot of maintenance of the coolant similar to what the prior PSDs that used the "plain jane" green coolant. I guess it's all the EPA stuff now on the engine.
I can't verify the validity of it, so take it for what you paid for it.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
Wxguru
Austin,AR
Posted: 04/08/12 01:29pm Link  |  Print  |  Notify Moderator
Buddy of mine has a 2011 F250 6.7L King Ranch and he is at 20,000 miles....no light so far.
2012 Dodge Ram 2500 4X4 Bighorn, 6.7L CTD
2011 Cherokee Grey Wolf 28A+KS
2010 Dodge Ram 2500 4X4 Laramie, 6.7L CTD--Owned 1 week!
2003 Dodge Ram Quad Cab 4X2, 5.7L HEMI--Retired Dec 2012
Flashman
Tucson, Aizona, USA
Posted: 04/08/12 03:03pm Link  |  Print  |  Notify Moderator
CLICKY
Larry
Those Ford Diesels just keep looking better and better!
craigwieck
michigan
Posted: 04/09/12 06:57am Link  |  Print  |  Notify Moderator
Alot of the cooling sys problems on the 6.0l is do to the coolant being left in the veh for to long. Ford said when they came out that it was good for 100,000 miles. That's about 70,000 to much. With all the coolers on these new motors its asking a lot of the cooling system. I change the coolant and trans fluid on my excursion ever year. Now I'm am a mechanic so its a lot cheaper for me than to have some one else do it. But I have also never seen a part go bad becaused you changed the fluids to much. I do know those new trucks have two cooling sys in them so doing a complete coolant change can take up to 8 to 10 gallons of coolant. But they are also high performance engines that may need a little more maintance than the older ones.
2010 larado 303tg
2005 excursion v10
NewsW
US
Posted: 04/09/12 07:27am Link  |  Print  |  Notify Moderator
If there is no overheating (e.g. failed oil / egr cooler).
If there is no tuner.
If there is no "performance" or other mods (e.g. EGR delete)
Coolant will barely make it to 100,000 miles.
A more reasonable interval is 60,000 to 80,000 miles or 5 years.
Regular testing of coolant (once a year) is a must plus replenishment of additives.
(If coolant fails to test repeatedly or there is unusual coolant depletion, replace at once).
The biggest single risk comes from failure to clean out old coolant and flush properly with VC-9 / Simple green (for grease and oil) during change.
If coolant chemistries are mixed, that is almost always fatal.
rexlion
Broken Arrow OK
Posted: 04/08/12 10:19pm Link  |  Print  |  Notify Moderator
My friend has decided that a visit with a dealership manager is in order, because if the pH was off (as they told him), they should have been able to put in the $15 additive instead of changing the coolant.
