RV.Net Open Roads Forum: Fifth-Wheels: Hitch install question
 > Hitch install question
porkchop1221
US
Posted: 04/05/12 07:26pm Link  |  Print  |  Notify Moderator
How easy or difficult is it to do so?
Just curious.
I won't be doing it, but I have friends that are extremely mechanical for a living....
Thanks!
Ps hijacker vs pull rite thoughts on the differences?
Thanks!
2012 GMC 3500HD, Diesel, Crew Cab Standard Bed, SRW
2013 Cyclone 3010 (to be picked up)
pressure_welder
brandon
Posted: 04/05/12 07:52pm Link  |  Print  |  Notify Moderator
A friend and myself installed my 16k husky fifth wheel hitch, took us about 1 hr to layout/drill rails. and install custom brackets. But about 2 hours to tighten all the bolts. I have a 2012 duramax and their is seriously less than 1" of room between the frame rail and box and ALOT of things in your way. Instructions recommend them to be torqued to 75ft/lbs. Best we could do is get a box end wrench on them and tighten them the best we could. Its a super simple job really if you can use a measuring tape/center punch/drill and torque wrench. Just be prepared for some bloody knuckles!
2012 Duramax Denali Dually
2003 Triple E topaz 29' luxury touring edition.
1850 crestliner sportfish w/ 150 optimax
wittmeba
Virginia
Posted: 04/06/12 11:05am Link  |  Print  |  Notify Moderator
Did my 2001 11 years ago but info is still pretty accurate.
http://www.gotnarcosis.com/brucewittmeie........technical/Reese16KSliderInstallation.htm
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
mbrule
Massachusetts
Posted: 04/06/12 02:30pm Link  |  Print  |  Notify Moderator
I used the custom brackets from Reese.
Was a straight-forward job. Took a good part of the day, but I did it alone and installed a connector in the bed, as well as cut the bed mat to fit.
ependydad
Columbia, MD
Posted: 04/06/12 02:32pm Link  |  Print  |  Notify Moderator
My reasoning for going with an installer is that I'm expecting it to be a cleaner/prettier look than what my friends might do.
2013 Sabre 36QBOK
Truck: 2012 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: B&W Turnover Ball + Companion hitch
Nights Camped: (2013: 10, 2012: 52, 2011: 28)
Blog about learning to RV, mishaps and adventures
porkchop1221
US
Posted: 04/06/12 11:54am Link  |  Print  |  Notify Moderator
Thank you for the replies! It doesn't seem too difficult if you have all the right tools (and you are handy). Luckily I have friends who are willing and probably able
bigjettech
Bartlett,Il
Posted: 04/06/12 09:00pm Link  |  Print  |  Notify Moderator
I looked at both hijacker and pullrite. Both seemed to have good reviews. I settled on the made in USA pullrite and have no regrets at all. Had a capture plate issue which was promptly taken care of by their customer support which was excellent. Took me about 4 hours to put mine in by myself with the underbed super rail kit. Read through the instructions first and a mechanically minded individual won't have any issues.
2006 Silverado 2500hd duramax 4x4 - with a few mods
2006 Cherokee lite 285b+ 5th wheel
davelinde
Lake Nona, Florida
Posted: 04/06/12 03:51pm Link  |  Print  |  Notify Moderator
On my Reese 16K install the hardest part was finding the right bit to drill the holes (it's an oddball size and ended up being pricey). I had good luck fishing the bolts through the frame on all but one (which got stuck and took a lot of jiggling to get it free'd up to try again). Oh yeah... a few of the bolts are torqued to feel and not with a torque wrench - I could not fit it into all spots.
Must be OK thought because it's towed some heavy stuff for a lot of miles and a lot of years now.
Dave Lindemulder
Tammy, Mark & Kirsten
04 Dodge 2500 4x4 SLT QC/SB HO-CTD/48RE
01 Volvo VNL660 singled VED12
09 Heartland Cyclone 3210
Pipewelder
Posted: 04/06/12 07:03pm Link  |  Print  |  Notify Moderator
Love my PullRite!!! The super rails for my Dodge used existing holes in the frame.
When you pull the hitch out nothing but 4 holes left in the bed. Hook up and no worries. Just pull baby pull!!!
Check em out.
http://www.pullrite.com/
bluck
Silver City, NM 88061 USA
Posted: 04/06/12 02:43pm Link  |  Print  |  Notify Moderator
It took 2 guys about 4 hours to install my Lil Rocker. This was at the rv dealer where I bought my fifth wheel. After I watched them strugle with tighting the bolts I was glad I didn't tackle it my self on my long bed crew cab Duramax.
2004 Chevy.
Duramax-Allison
2004 Thor Mirage
Kawasaki Prarie 700
