RV.Net Open Roads Forum: Water pressure regulators that still let the water flow???
 > Water pressure regulators that still let the water flow???
steelpony5555
Copperas Cove Texas
Posted: 04/05/12 11:00pm Link  |  Print  |  Notify Moderator
I have tried several water pressure regulators but it seems they cut the pressure coming in even when the pressure is fine. What I mean is if the park has 40 psi the regulator cuts it back to 20 psi. Is there a decent regulator out there that will only hold back the pressure if it goes above 50 psi. Or is a pressure regulator really necessary. I haven't really run into a place with extreme pressure yet.
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
rk911
Wheaton IL
Posted: 04/05/12 11:20pm Link  |  Print  |  Notify Moderator
short answer...yes. you've probably been using one of those cheap ($6-$10) regulators. they don't regulate pressure...they regulate flow which is different than pressure.
you need a real pressure regulator. we use a Watts model 263A. with it you can adjust the pressure to between 10-65 gpm. i keep ours set to approx. 50-gpm so if we hook up to a park with pressure more than that the regulator will automatically keep the pressure at 50-gpm. one tip...if you get one of these get the stainless steel model and avoid the rust.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
hershey
Albuquerque,(fulltime) NM, USA
Posted: 04/05/12 11:49pm Link  |  Print  |  Notify Moderator
Watts regulator is exactly what you want. Costs a lot more money than the Mickey Mouse $5.00 regulators from Wally World but, it will do exactly what your seeking.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
LostinAZ
At Home
Posted: 04/05/12 11:53pm Link  |  Print  |  Notify Moderator
If you don't want to spend a whole lot of Money try the Valterra Hi-Flow fixed Brass regulator from Camping World. This is around 55 PSI where as the regular version of this is in the 40 to 50 PSI. We have found that this provides just enough more flow to be satisfactory for us. YMMV.
wny_pat
Western NYS
Posted: 04/05/12 11:29pm Link  |  Print  |  Notify Moderator
I think rk911 means psi, not gpm. 50 gallons a minute out of a motorhome facet is like !!! But 50 psi and 4-4.5 gpm is . In fact, I'm sure that is what he meant.
sdianel
Tampa, FL
Posted: 04/05/12 11:30pm Link  |  Print  |  Notify Moderator
Watts makes pressure regulators and they sell them thru Lowe's. Lowes can special order if they don't have it in stock. Don't buy the cheapest one. Look on www.lowes.com and read the reviews.
* This post was edited 04/05/12 11:45pm by an administrator/moderator *
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
Golden_HVAC
Fulltime, CA, USA
Posted: 04/05/12 11:59pm Link  |  Print  |  Notify Moderator
Hi,
Home Depot has a pressure gauge that is already mounted to a hose connection, so you can test the incoming pressure when you plan on hooking up. If the pressure is under 45 PSI, no need for a regulator, and you will get a lot of water out of the fascets!
I have a Home Depot pressure regulator. Yes they sell them in 3/4" size, with very little water flow restrictions, kinda large though, made for a house more than a RV. I installed brass connections for both the inlet and outlet hose connections. I sometimes use a 4' long drinking water hose with this set-up. I normally use just the standard RV regulator, as I don't really need more than the 2 GPM they put out.
Fred.
Executive
Posted: 04/06/12 03:31am Link  |  Print  |  Notify Moderator
Home Depot also sells the Watts Regulators...a few bucks cheaper than Lowes...We have ours set at 55psi and mount it off the water source just before the whole house filter....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
SWD
Land of Living Skies
Posted: 04/06/12 03:48am Link  |  Print  |  Notify Moderator
Watts H560 here. The best thing since they invented regulators!
rk911
Wheaton IL
Posted: 04/06/12 09:23am Link  |  Print  |  Notify Moderator
LMAO...well, it *would* be something if i could get 50-gpm in the motorhome, wouldn't it. sigh...i am getting old-er. yes...the watts regulator is pre-set for 4.5-5-gpm and i keep ours set around 50-psi. thanks for catching that.
i also use an inline pressure gauge in combination with the watts regulator. the pressure gauge measures the inbound pressure to the regulator. this allows me to instantly see the native pressure of the water system as compared to the regulated pressure. and as i mentioned earlier...if i had to do it all over again i would opt for the stainless steel versions of each.
* This post was edited 04/06/12 09:47am by rk911 *
