RV.Net Open Roads Forum: What is safest TV towing attitude - raked or level?
Search only in Towing
Open Roads Forum  >  Towing
 > What is safest TV towing attitude - raked or level?
Apollo99
Home
Posted: 04/06/12 01:50am Link  |  Print  |  Notify Moderator
I have a 2012 Ram 1500 Big Horn CC TV. I tow a 7150 lb 29' TT with 850 lb TW using Reese WD Dual Cams and rear Air Lift 1000 air bags (to compensate for mushy rear coil springs in Ram). What is the safest recommended towing attitude of the TV? I can adjust for a level TV resulting in nearly a 2" squat compared to the unloaded attitude. OR I can raise the rear resulting in an attitude nearly identical to unloaded attitude. In both cases, the WDs are adjusted so front height is same as unloaded. Any recommendations?
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/06/12 02:44am Link  |  Print  |  Notify Moderator
Level truck and level trailer is the proper attitude. If you're going to err, err nose-low on the trailer, not nose-high.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
eye8Ubutler
Maritime Provinces
Posted: 04/06/12 05:21am Link  |  Print  |  Notify Moderator
"Mushy Rear Coils"......I have waited to hear from a Poster re. the 09 onwards Ram 1500 rear coils!
I am considering a brand new 1500 TV for 2013 season?
My 'signature' TV with factory Max Tow package is rated to pull 10,500lbs (as per Driver's Handbook).
How is your TV working out please?
Chevrolet Silverado 1500 LTZ 2007 (new shape)
4x4 Crew Cab VORTEC MAX (L76) 6.0L V8 4L70E 4.10 axle
factory NHT Max Trailering Package.
2010 Coachmen Freedom Express 280 RLS
"...a Waldorf Salad?, sorry we are fresh out of Waldorfs!".......BASIL FAWLTY.
skipnchar
Topeka or somewhere else
Posted: 04/06/12 07:31am Link  |  Print  |  Notify Moderator
Level is the goal. Perfection is usually not required.
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/06/12 08:59am Link  |  Print  |  Notify Moderator
I suspect those mushy rear coil springs can be replaced with heavier duty coil springs, if anyone makes them yet.
christopherglenn
a little over an hour from Yosemite
Unloaded is how it was when it alligned. Squat the rear a few inches and the allignment changes, but not by much.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
rasteck
Northern California/East Bay
Posted: 04/06/12 09:27am Link  |  Print  |  Notify Moderator
With my rig, having both as level as possible significantly reduces the chucking we get on the freeways around here.
2000 Ram 2500 SLT/Laramie 24V CTD 2WD QCSB PacBrake, Smarty
2011 Colorado 320BS-FW 36'
EZ Flex + wet bolt
Curt E5 with R5 slider, Prodigy P3
Air Lift 5000's, Load Controller II
Desert Captain
Tucson
Posted: 04/06/12 10:00am Link  |  Print  |  Notify Moderator
I get no more than a half a degree of down bubble at the front of the trailer fully loaded (including 15 gal of fresh water in the forward tank). A lighter load out gets me to dead level. This for a 22', 4600# TT with lots of stuff under the shell in the back of my F-150 SCab. This combo tows like a dream and I have never come close to encountering anything remotely resembling sway. Keep it level or just a tad bow down for the best towing experience.
Apollo99
Home
Posted: 04/06/12 10:16am Link  |  Print  |  Notify Moderator
I know to keep the TT as level as possible (maybe nose down abit). My question is refering to the attitude of the TV. Level OR ass end raised to match the unloaded attitude?
Dave&Monica
Ontario
Posted: 04/06/12 10:53am Link  |  Print  |  Notify Moderator
I'd say that you adjust the W/D bars to a point where the truck's front height (as measured at the front wheel well) stays the same as when unhitched.
Dave
2010 Rockwood 8280WS
2008 F250 CC Lariat SB 6.8L V10
