smkettner
mexbungalows wrote: Those of you whom harp to use nothing on wheel studs, please come here, I have several wheels stuck on friend's cars that need your magic.
Loosen the nuts 1 turn and drive the vehicle a few feet.
675 watts solar
7ofus
Georgia
msiminoff wrote: 7ofus wrote: I would love to see the force diagram of how the clamping force on the studs translates to the radial force on the hub centered wheel.
Okay, since you asked...
Note that due to the clearance fit, there is no force transmitted by or as a result of the centering feature. Neither this force diagram nor my previous explanation have anything to do with wheel centering. Keep in mind that many vehicles use only the wheel studs for centering.
I believe that you are proving the need for friction on the hub face to wheel interface, and I do not disagree with you. I am suggesting the need for lube on the hub center to wheel interface - which is unaffected by the stud clamping forces. We are arguing different points. So how about we both win?
ChopperBill
Colo
The only wheel stud I have had a problem with came loose about 2 turns and galled the threads and spun the bolt in the hub. Had to take the hub off and cut the bolt in half. Worse part is I always used never seize until that happened. Wont go with out the never seize again.
danskool
Elma, N.Y.
I have always used anti-seize on studs and hubs..
Dan
2005 Crossroads Cruiser 27RL
2001 F250 XLT 7.3 PSD
MEXICOWANDERER
las peƱas, michoacan, mexico
EXCELLENT TIP! Sadly cannot back the lug nuts off one turn :-(
srt20
Wisconsin
I love threads like this! great entertainment value!
dan-nickie
Grand Prairie, TX
This is cool..........
Dan and Nickie, Four Winds 31p, Retired Jan/2011
LarryJM
NoVa
7ofus wrote: msiminoff wrote: 7ofus wrote: I would love to see the force diagram of how the clamping force on the studs translates to the radial force on the hub centered wheel.
Yep and that centering interface was all I was saying it is O.K. to lubricate, not the entire hub or wheel surfaces. The lube on the wheel pilot to hub interface will prevent the wheel sticking to the hub due to rust at that very close tolerance interface.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
westend
all over
I sometimes use lubrication on lug studs and on the rim to hub interface. If the lug nuts are fastened to a correct torque, there is little chance of loosening while underway. Retorquing lug fasteners after a short mileage interval is a good safety precaution.
I've had some minor skirmishes with rusted lugs and, recently, aluminum rims on steel hubs. Some judicious use of heat and cold water on the nut or on the rim, will make life tolerable again.
'03 F-250 4x4 CC
RJsfishin
Winston Or.
Conclusion,.......just like always,
Do what you wanna to do, cuz you gonna do it that way anyway, and its legal, cuz it's your nuts if it don't work !
Rich
'01 31 ft Rexall Vision, Generac 5.5k, 9245 conv, 400 watt inv, 2 12v batts, ammeters, KingDome/sat, Two Oly Cat heaters, and towing a '05 Jeep Liberty, or sometimes towing a Lowe bass boat.
