RV.Net Open Roads Forum: Should I use Never Seize on Wheel Lugs?
 > Should I use Never Seize on Wheel Lugs?
Page of 6
therink
Rochester
Posted: 04/06/12 05:15am Link  |  Print  |  Notify Moderator
I am in the process of upgrading to EZ Flex Suspension on my fiver. My neighbor recommended that I use Never Seize on the wheel studs when putting the wheels back on. I have aluminum wheels and torque wrench and will torque the lugs to spec but not sure if I should use the never seize or not. I have heard differing opinions, but want to do the right thing.
Thanks.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
LarryJM
NoVa
Posted: 04/06/12 05:26am Link  |  Print  |  Notify Moderator
Thanks.
Those that I consider the real experts such as a person that has designed wheels and hub systems for over 35 years for car companies and folks whose job are brake testing certification for OEM vehicle manufacturers both say to use nothing on the actual studs. A little oil on the wheel to hub pilot surfaces is O.K. but use nothing on the studs themselves.
Wheel torque values are based on just clean metal to metal conditions and introducing anything can drastically effect the true holding power of that critical connection.
Larry
* This post was edited 04/06/12 07:07am by LarryJM *
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
Jim Cindy
Northcentral, PA
Posted: 04/06/12 05:56am Link  |  Print  |  Notify Moderator
No lubricants anywhere a torque value is used. Never Seize acts as a lubricant.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
beemerphile1
I'm 57, I'm not a
Posted: 04/06/12 07:05am Link  |  Print  |  Notify Moderator
Feel free to use Never-seize on lugs if your goal is to stretch and break the lugs when you overtorque them. Otherwise no lube should ever be used.
- Soren Kierkegaard
bingford
Utah
Posted: 04/06/12 07:06am Link  |  Print  |  Notify Moderator
There are 'wet" torque and "dry" torque values, where "wet" is a lubricated thread and dry is a clean non-lubricated thread. A K-Factor is assigned to the lubricant that adjusts (lowers) the torque requirement by a percentage. This prevents over-tightening which results in metal fatigue and stripped threads.
I have used blue Loctite on lug nuts, loweing the torque setting by 30%. This provides a seconday locking mechanisim and also prevents moisture corrosion and lowers risk of galvanic corrosion.
recycler
michigan
Posted: 04/06/12 07:36am Link  |  Print  |  Notify Moderator
wouldn't use never seize on wheel studs or the seat on the wheel i would be sure to check the wheels often
1968 franklin 11fk
back to my 93 cummins
retired-tech
flint mi
Posted: 04/06/12 08:00am Link  |  Print  |  Notify Moderator
NEVER use ANY lube on any part of wheel mounting surface. especially not between the wheel and hub. the wheel requires the surface friction. keep things clean and you wont have any problems.
2000 K3500 CCLB DRW 6.5 TURBO
2009 Cougar 320 SRX
2007 atlas 24 auto hauler
1987 GMC origional low miles
7ofus
Georgia
Posted: 04/06/12 08:40am Link  |  Print  |  Notify Moderator
I completely understand no lube on the wheel studs, but can you explain the reason for no lube between the wheel and hub?
RJsfishin
Winston Or.
Posted: 04/06/12 08:47am Link  |  Print  |  Notify Moderator
I'll always use some kind of lube on all wheel lugs, and always have,.......for 50 yrs. I don't use a torque reading. I use common sense of feel.
Dry metal to metal contact tends to "gall". When it galling, a torque reading doesn't mean anything. And when a lug won't come loose and breaks, its because it galled !
But believe whatever,....its your lugs !
Rich
'01 31 ft Rexall Vision, Generac 5.5k, 9245 conv, 400 watt inv, 2 12v batts, ammeters, KingDome/sat, Two Oly Cat heaters, and towing a '05 Jeep Liberty, or sometimes towing a Lowe bass boat.
jauguston
Bellingham, WA
Posted: 04/06/12 09:13am Link  |  Print  |  Notify Moderator
After having studs break due to siezed lug nut threads and wheels frozen to the hub I always use never sieze.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Page of 6
