RV.Net Open Roads Forum: General RVing Issues: Another gray/black question, sorry.
 > Another gray/black question, sorry.
BigSur2
Hampton, VA
Posted: 04/06/12 05:34am Link  |  Print  |  Notify Moderator
I didn't bother trying to find this....would probably be like finding a needle in a hay stack.
Does anyone know exactly how much water is needed to cover just the bottom of a 30 gallon gray or black tank? I assume this is different for every unit right?.....considering that everyone's linear footage of drain lines is different.
Just curious if there's a rule of thumb, but knowing me, I'll probably end up measuring my drain length and calculating how much water I need to fill them first based on length and diameter...that will then give me an idea on how much more I need to cover the bottom of the tank.
Reason I ask is I'm trying to keep my TT as light as possible. I don't want unnecessary fluids in my tanks.
Thanks in advance!!!!!!
BigSur2
2012 Keystone Bullet 286QBS
2006 Ford F150 5.4 V8
pianotuna
Regina, SK, Canada
Posted: 04/06/12 05:44am Link  |  Print  |  Notify Moderator
Hi,
If you want as light as possible put no water at all in the waste tanks. They will fill up just fine as they are used.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Wills250psd
walnutcove NC
Posted: 04/06/12 05:47am Link  |  Print  |  Notify Moderator
Get a 5 gallon bucket, pour one down the toilet and pour one down the kitchen sink and you will be fine. NEVER,NEVER be sorry to bother us with a question thats why this site exist. I never use the search feature if I need to know something I want (live) answers. wills250psd
paulcardoza
Southeastern Massachusetts
Posted: 04/06/12 05:49am Link  |  Print  |  Notify Moderator
Cover it how deep? If it's dead level, a half gallon will cover the bottom. Personally, I flush about 3 gallons into my 40gal blank tank after dumping. Gives me a good start for the next fill.
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
skipnchar
Topeka or somewhere else
Posted: 04/06/12 06:16am Link  |  Print  |  Notify Moderator
I suspect you're trying to prevent solids building up by drying out completely which is fine but if you're towing the trailer the movement of the water will keep the bottom wet even if you don't have enough to actually cover the bottom. I think you're probably being a little TOO concerned about weight but maybe you have a good reason. If it's fuel mileage the difference of a couple of hundred pounds would still be unmeasurable in the long term. Might make a significant difference though over a couple of hundred thousand miles but not many ever tow that much.
BigSur2
Hampton, VA
Posted: 04/06/12 06:37am Link  |  Print  |  Notify Moderator
Thanks....to clarify, I NEVER leave my tanks dry. As Skip indicates, I like to avoid buildup and drying of solids. Weight isn't THAT big of an issue, but it IS an issue. My TT/TV combination is sufficient, but I'm competent enough to know that I'm pushing my limits, especially on my "mountain" trips.
I agree that just a little bit on the bottom is all that is needed. I used to only put about 1.5 gallons in each after dumping, but then I realized that the 1.5 gallons might just be sitting in the drain line....not in the tank. On my old Jay Flight I had a few feet of 3 to 4" diameter drain pipe from the tank to the valve, so I assume most of my water was just sitting in the pipe, not the tank. Subsequently, I started adding more but never new how much I really needed to fill the drain AND cover the tank bottom.
I need to take a closer look at my drain system on my new Keystone. My valves might be much closer to the tank which eliminates this uncertainty.
I'm aware I'm going a little overboard on this.....I'm a true perfectionist. Just can't help myself. Thanks again guys!!!!!!
dalenoel
S.E. Michigan
Posted: 04/06/12 06:56am Link  |  Print  |  Notify Moderator
If your tank is 24" x 40" then you have 960 sq. in and covering it 1/2 inch deep will use 2.08 gallons of the capacity of the tank.
If the tank is half that size you would use half the amount of water but that would mean the tank is 15 inches tall and that does not sound right.
04 Dodge RAM Quad Crew Cab 4x4
08 Jayco Eagle 322 FKS, Hensley Arrow, Prodigy Controller
Wife and myself, Lutheran Deacon, Oreo the Malshi, and maybe a grandkid or two
BigSur2
Hampton, VA
Posted: 04/06/12 06:40am Link  |  Print  |  Notify Moderator
P.S. Nice truck skip. I will be going for the Ecoboost as well when time to sell. Keeping my current TV until the wheels fall off though.
pianotuna
Regina, SK, Canada
Posted: 04/06/12 06:41am Link  |  Print  |  Notify Moderator
Hi BigSur2,
I would not dare to leave water in my waste tanks in winter time.
BigSur2
Hampton, VA
Posted: 04/06/12 07:12am Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi BigSur2,
Wintertime it's antifreeze in place of water.
