RV.Net Open Roads Forum: Should I have followed truck manufacturer's specs or not?
 > Should I have followed truck manufacturer's specs or not?
gmcsmoke
Butler
Posted: 04/06/12 11:06am Link  |  Print  |  Notify Moderator
TonyInPa wrote:
Thanks for all your advice.
Details:
2007 Tundra TRD Off Road. 5.7 l
KZ Spree fifth-wheel. I think 28 feet. 5,800 pounds dry weight.
Now it's going to get good.
christopherglenn
a little over an hour from Yosemite
Posted: 04/06/12 11:09am Link  |  Print  |  Notify Moderator
I wouldn't pull a 5th wheel with P tires on the truck.
Next time you head out, fuel up and weigh your rig fully loaded. See how close you are (axle weights) to the tire ratings.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
downtheroad
Pacific Northwest
Posted: 04/06/12 11:11am Link  |  Print  |  Notify Moderator
Details:
What in the world is Toyota doing putting "P" tires on this truck in the first place?
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
BUFFALODAN
Buffalo NY
Posted: 04/06/12 11:27am Link  |  Print  |  Notify Moderator
Not sure why any truck that comes with a "heavy duty towing package" wouldnt have LT tires as part of that package.
I switched to LTs years ago. The difference towing with them was a big improvement.
2006 KZ Frontier 2505
2005 Chevy Suburban 1500 Z71 4WD
2011 GMC Sierra 1500 SLE Crew Cab 4WD
1 DW
3DD's
dodge guy
Bartlett IL
Posted: 04/06/12 11:35am Link  |  Print  |  Notify Moderator
I would go to a LT "C" rated tire. this would be a nice upgrade from your current P tires. I wouldn`t go to a "D" or "E" rated because your 1/2 ton axle rating would be nowhere near needing them.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
rwgeiser
Anchorage, Alaska
Posted: 04/06/12 11:37am Link  |  Print  |  Notify Moderator
Please note that if you change to LT tires DO NOT exceed recomended wheel pressures when inflating
Ron & Del
2003 Fleetwood, Storm 30H
P32 Chassis
Part-Timer, Retired
fla-gypsy
North Florida
Posted: 04/06/12 01:42pm Link  |  Print  |  Notify Moderator
Oh where to start with this one.........
elkhornsun
Monterey
Posted: 04/14/12 01:39am Link  |  Print  |  Notify Moderator
For the tires that come in both a D and an E rating the people driving the E rated tires are getting 25-30% more miles per set of tires. I would expect that is you have a heavy load in your truck much of the time that the D rated tires are going to flex more and scrub themselves to death as you drive and you are likely to be disappointed with the tread wear experience. The 10 Ply E rated tires that I have been looking at are on average 25-30% more expensive than the P rated ones so in terms of cost per mile it is about the same.
mowermech
Billings, MT
Posted: 04/06/12 02:23pm Link  |  Print  |  Notify Moderator
TonyInPa wrote:
My truck manufacture'sr specs call for P tires on my truck.
A friend, who doesn't really tow much, said I definitely should use LT tires.
Am I O.K. towing with P tires?
OK? Probably.
But I wouldn't do it. IMO, TRUCKS should have Light Truck (LT) tires.
Also, IMO, the tires should be real traction tires, for best safety.
But, it is your truck, not mine, do it your way.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
